Timeout using IIS 8.5
hi buddy, can you tell me what configuring was you did on IIS ? I got same problem here, and stuck with the same error
Hi @DAdjiee
I’ve moved your post to a new topic, that makes things easier.
There is a standard template from #help
You need an open port 80 to use http-01 validation.
