My domain is: u22961052.onlinehome-server.com
I ran this command: 'Get it free' from within Plesk [I'm trying to get things working within Plesk if at all possible before resorting to the command line]
It produced this output: > Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/153002134597.
Details:
Type: urn:ietf:params:acme:error:connection
Status: 400
Detail: 74.208.79.181: Fetching https://u22961052.onlinehome-server.com/.well-known/acme-challenge/mgMFlXo1A5SAhw2kPaXD4dJUJr9hwHktMfd1L76ml_0: Timeout during connect (likely firewall problem)
My web server is (include version): Nginx 1.20.2
The operating system my web server runs on is (include version): Ubuntu 20.04.5 LTS
My hosting provider, if applicable, is: IONOS 1 and 1
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk 18.0.43
or certbot-auto --version
if you're using Certbot): certbot 1.30.0 [although I do not know if Plesk uses that client or not]
Reading through the other topics with a similar title, I saw a reference to /var/log/letsencrypt/letsencrypt.log. That file contains the following. However, the timestamps in that file do not line up with my Plesk-initiated requests and re-running the Plesk-initiated request does not change the log file.
2022-09-13 05:50:03,899:DEBUG:urllib3.connectionpool:http://localhost:None "GET /v2/connections?snap=certbot&interface=content HTTP/1.1" 200 97
2022-09-13 05:50:04,536:DEBUG:certbot._internal.main:certbot version: 1.30.0
2022-09-13 05:50:04,536:DEBUG:certbot._internal.main:Location of certbot entry point: /snap/certbot/2344/bin/certbot
2022-09-13 05:50:04,536:DEBUG:certbot._internal.main:Arguments: ['-q', '--preconfigured-renewal']
2022-09-13 05:50:04,536:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-09-13 05:50:04,622:DEBUG:certbot._internal.log:Root logging level set at 40
2022-09-13 05:50:04,633:DEBUG:certbot._internal.display.obj:Notifying user: Processing /etc/letsencrypt/renewal/u22961052.onlinehome-server.com.conf
2022-09-13 05:50:04,661:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x7f0d5039a460> and installer <certbot._internal.cli.cli_utils._Default object at 0x7f0d5039a460>
2022-09-13 05:50:04,690:DEBUG:urllib3.connectionpool:Starting new HTTP connection (1): r3.o.lencr.org:80
2022-09-13 05:50:04,851:DEBUG:urllib3.connectionpool:http://r3.o.lencr.org:80 "POST / HTTP/1.1" 200 503
2022-09-13 05:50:04,853:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/u22961052.onlinehome-server.com/cert2.pem is signed by the certificate's issuer.
2022-09-13 05:50:04,854:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/u22961052.onlinehome-server.com/cert2.pem is: OCSPCertStatus.GOOD
2022-09-13 05:50:04,859:DEBUG:certbot._internal.display.obj:Notifying user: Certificate not yet due for renewal
2022-09-13 05:50:04,860:DEBUG:certbot._internal.plugins.selection:Requested authenticator nginx and installer nginx
2022-09-13 05:50:04,865:DEBUG:certbot._internal.plugins.selection:Selecting plugin: * nginx
Description: Nginx Web Server plugin
Interfaces: Installer, Authenticator, Plugin
Entry point: nginx = certbot_nginx._internal.configurator:NginxConfigurator
Initialized: <certbot_nginx._internal.configurator.NginxConfigurator object at 0x7f0d5039efa0>
2022-09-13 05:50:04,866:DEBUG:certbot._internal.display.obj:Notifying user:
2022-09-13 05:50:04,866:DEBUG:certbot._internal.display.obj:Notifying user: The following certificates are not due for renewal yet:
2022-09-13 05:50:04,866:DEBUG:certbot._internal.display.obj:Notifying user: /etc/letsencrypt/live/u22961052.onlinehome-server.com/fullchain.pem expires on 2022-11-28 (skipped)
2022-09-13 05:50:04,866:DEBUG:certbot._internal.display.obj:Notifying user: No renewals were attempted.
2022-09-13 05:50:04,866:DEBUG:certbot._internal.display.obj:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2022-09-13 05:50:04,866:DEBUG:certbot._internal.renewal:no renewal failures
