An unexpected error occurred:
There were too many requests of a given type :: Error creating new cert :: too many certificates already issued for: XX.io: see https://letsencrypt.org/docs/rate-limits/
The operating system my web server runs on is (include version): linux
Basically I don`t have any problems, I mess up little bit with code in cert requests went in loop, so I reached a limit, when I noticed this I fixed the issue, and now it works fine with --staging flag but when request for production fall on limits, is there a way how to drop limits and proceed with new certificate today? as now code works fine.
The one workaround available to you is to add another domain/subdomain to the certificate (even if you don't need it), which will cause it to be counted against a different rate limit bucket.
You can also look up your certificates on https://transparencyreport.google.com/https/certificates which may be a bit more up-to-date , and count exactly 7 days after the earliest duplicate certificate from within the last 7 days.
