The server will not issue certificates for the identifier :: NewOrder request did not include a SAN short enough to fit in CN
My domain is: alotofyoumaybeaskingwhyareyouavirginisaytothemidkwhyami.tk right now but i want to change it to alotofyoumaybeaskingwhyareyouavirginisaytothemiampoggersgfisnot.international
I ran this command: sudo certbot --nginx -d alotofyoumaybeaskingwhyareyouavirginisaytothemiampoggersgfisnot.international
An unexpected error occurred:
My web server is (include version): Nginx 1.18.0
The operating system my web server runs on is (include version): Ubuntu Server 20.04.2
My hosting provider, if applicable, is: IONOS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.40.0
For some technical/historical reasons, certificates issued by Let's Encrypt need to include at least one domain name which is less than 64 characters.
This will change one day in the future, but at the moment, there is no workaround other than to add a second name which fits that constraint.
With or without the TLD?
The full domain: with the TLD.
And to be clear, you can get a certificate for your long domain, it's just that you will need to complement it with a second, shorter domain.
How would I do that?
You'd register a second domain like lessthan64chars.tk and point it at your server, then when you want the certificate for alotofyoumaybeaskingwhyareyouavirginisaytothemiampoggersgfisnot.international, you'd do:
certbot --nginx -d lessthan64chars.tk -d alotofyoumaybeaskingwhyareyouavirginisaytothemiampoggersgfisnot.international
Would I point the less characters name to my server directly with an A record or point it to the domain with a CNAME record?
Either would be fine, but the CNAME would probably be easier from an administrative perspective.
If I am using a subdomain, it now does this:
Error while running nginx -c /etc/nginx/nginx.conf -t.
nginx: [emerg] a duplicate default server for 0.0.0.0:80 in /etc/nginx/conf.d/hopefullythisgetstoguinessworldrecordssomehowihopethisdoesplsdo.alotofyoumaybeaskingwhyareyouavirginisaytothemiampoggersgfisnot.international.conf:24
nginx: configuration file /etc/nginx/nginx.conf test failed
This part of the error says it all: you shouldn't designate multiple server blocks as default server.
But I haven't, just one.
Could you please post the output of sudo nginx -T ?
If you show this file, we can all see the problem:
