The requested <plugin> does not appear to be installed
I have 2 plugins for PowerDNS installed via pip. Certbot doesn't find either of them. It used to. I've seem similar topic in here, but nothing quite like I'm dealing with. Thanks for the help.
My domain is: voyant.com
certbot certonly -n --logs-dir /var/log/certcron/_.TEMPvoyant.com --authenticator certbot-dns-powerdns:dns-powerdns -d *.voyant.com --cert-name voyant.com --agree-tos --email "devops@voyant.com"
The requested certbot-dns-powerdns:dns-powerdns plugin does not appear to be installed
My web server is (include version): NA
The operating system my Certbot runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: NA
I can login to a root shell on my machine (yes or no, or I don't know): YES
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): NO
certbot 2.1.0
The other domain that produces the same error
root@ply-certbot-u20-01:/srv/certbot/PDNStest# certbot certonly -n --logs-dir /var/log/certcron/_.TEMPvoyant.com --authenticator certbot-pdns:auth -d *.voyant.com --cert-name voyant.com --agree-tos --email "devops@voyant.com"
Saving debug log to /var/log/certcron/_.TEMPvoyant.com/letsencrypt.log
The requested certbot-pdns:auth plugin does not appear to be installed
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/certcron/_.TEMPvoyant.com/letsencrypt.log or re-run Certbot with -v for more details.
root@ply-certbot-u20-01:/srv/certbot/PDNStest# pip list | grep cert
certbot                 2.1.0
certbot-dns-dnsmadeeasy 1.22.0
certbot-dns-powerdns    0.2.1
certbot-pdns            1.2.0
certifi                 2019.11.28
root@ply-certbot-u20-01:/srv/certbot/PDNStest# certbot plugins --text
* auth
Description: Place challenges in DNS records
Interfaces: Plugin
Entry point: auth = certbot_pdns.authenticator:Authenticator
* dns-dnsmadeeasy
Description: Obtain certificates using a DNS TXT record (if you are using DNS
Made Easy for DNS).
Interfaces: Authenticator, Plugin
Entry point: dns-dnsmadeeasy =
certbot_dns_dnsmadeeasy._internal.dns_dnsmadeeasy:Authenticator
* dns-powerdns
PowerDNS for DNS.)
Entry point: dns-powerdns = certbot_dns_powerdns.dns_powerdns:Authenticator
* standalone
Description: Spin up a temporary webserver
Entry point: standalone = certbot._internal.plugins.standalone:Authenticator
* webroot
Description: Place files in webroot directory
Entry point: webroot = certbot._internal.plugins.webroot:Authenticator
Hi @erglazier (Rich) and welcome to the community!
I might be missing something, but It looks like you should be using:
Registrar WHOIS Server: whois.godaddy.com
certbot-dns-godaddy x.xx.xx plugin...
At any rate your command shows:
So whatever DNS plugin is not installed.
Some of the questions go unanswered
Hosting provider?
Are you "self hosted?"
Using godaddy?
Please advise.
In the changes for Certbot 2.0:
  • 3rd party plugins no longer support the dist_name:plugin_name format on the CLI and in configuration files. Use the shorter plugin_name format.
So, you'd just do:
--authenticator auth
for the PowerDNS plugin.
Sorry _az, I meant to mention that I tried that as well, but it's like -a doesn't like see the argument.
root@ply-certbot-u20-01:~# certbot certonly -n --logs-dir /var/log/certcron/_.TEMPvoyant.com --authenticator auth -d *.voyant.com --cert-name voyant.com --agree-tos --email "devops@voyant.com"
usage:
  certbot [SUBCOMMAND] [options] [-d DOMAIN] [-d DOMAIN] ...
Certbot can obtain and install HTTPS/TLS/SSL certificates.  By default,
it will attempt to use a webserver both for obtaining and installing the
certificate.
certbot: error: argument -a/--authenticator: expected one argument
I suspect that "auth" is a keyword.
Try encapsulating it.
Thanks for the feedback. Not using GoDaddy, and am self hosted. The plugin I'm trying to get recognized is certbot-pdns:auth
That would be:
OR
--authenticator dns-powerdns
Good idea, I tried putting auth in single quotes and double quotes, but the same output.
Would be:
OR
--authenticator 'auth'
OR maybe...
--authenticator '\a\u\t\h'
Thank you rg305. Here is the way is was working, before upgrading to v2.
Here's the plugin
* auth
Interfaces: Plugin
# pip list | grep certbot-pdns
certbot-pdns            1.2.0
# certbot certonly -n --logs-dir /var/log/certcron/_.TEMPvoyant.com --authenticator '\a\u\t\h' -d *.voyant.com --cert-name voyant.com --agree-tos --email "devops@voyant.com"
The requested \a\u\t\h plugin does not appear to be installed
# certbot certonly -n --logs-dir /var/log/certcron/_.TEMPvoyant.com --authenticator 'auth' -d *.voyant.com --cert-name voyant.com --agree-tos --email "devops@voyant.com"
usage:
certificate.
# certbot certonly -n --logs-dir /var/log/certcron/_.TEMPvoyant.com --authenticator certbot-pdns -d *.voyant.com --cert-name voyant.com --agree-tos --email "devops@voyant.com"
The requested certbot-pdns plugin does not appear to be installed
I have the other PowerDNS plugin installed as well, and the short form of that authenticator worked, so maybe I can just use that PDNS plugin? :person_shrugging:
root@ply-certbot-u20-01:~# certbot certonly -n --logs-dir /var/log/certcron/_.TEMPvoyant.com --authenticator dns-powerdns -d *.voyant.com --cert-name voyant.com --agree-tos --email "devops@voyant.com"
Certificate not yet due for renewal; no action taken.
Give that one a go, while I try to dig up some other hack to that "keyword"...
Try:
--authenticator \a\u\t\h
Thank You.
He meant Godaddy for your authoritative DNS zone.
But I guess that answer fits there too - lol
I remember that issue from before and I got excited for a second, but I don't think that's the case here.
Following these steps, I was able to install and use the certbot-pdns plugin via the auth entrypoint:
sudo python3 -m venv /opt/certbot/
sudo /opt/certbot/bin/pip install --upgrade pip
sudo /opt/certbot/bin/pip install certbot certbot-pdns
sudo ln -s /opt/certbot/bin/certbot /usr/bin/certbot
sudo certbot certonly -d example.com -a auth --dry-run
An unexpected error occurred:
FileNotFoundError: [Errno 2] No such file or directory: '/etc/letsencrypt/certbot-pdns.json'
-a auth
Should be the same ...
But do they act the same?
-a and --authenticator behave the same way, and neither recognizes "auth". Thanks for all the suggestions, however.
I went ahead and changed to a different plugin for Power DNS certbot-dns-powerdns, because I could never get the certbot-pdns:auth working
