The problem with updating the certificate
I am trying to update my certificate, but I get an error when updating
It looks like the ACME client is trying to access the ACME version 1 API server endpoint, which is already phased out. The ACME client requires reconfiguration to use ACME V2, and that may involve software upgrade.
I downloaded a new software and when I try to issue it I get the following
The server gives 502 Bad Gateway error. You may want to check the web server (or frontend proxy, if it applies) configuration.
Are you sure you are on the right system?
You seem to be using a Windows system but the system that answers at that FQDN shows:
server: Caddy
