There is, on that line 134.
Do you see that weird grey-and-black rectangle on the end of the line?
I think that’s the bad hidden character. It might not be visible in a text editor. It probably got there through some kind of copy-and-paste operation.
I think if you delete everything past the #
on that line, the problem should go away.
Check again with the grep
afterwards that it’s gone.
