Ubuntu 18.04.02 Server Edition, nginx/1.14.0 (Ubuntu) , domain: ggc.world (under heavy development)
As follow-up of my previous attempts to automate certificates renewal (Certbot-renewal.service: Failed with result 'exit-code + How to be sure that the automatic certificates renewal process is correctly set? Ubuntu 18.04.02 Server ) , I installed certbot via sudo pip install .
marco@pc:~$ sudo certbot renew --dry-run
An unexpected error occurred:
ContextualVersionConflict: (cryptography 2.1.4 (/usr/lib/python2.7/dist-packages),
Requirement.parse(‘cryptography>=2.3’), set([‘PyOpenSSL’]))
Please see the logfile ‘/tmp/tmp2KOWbQ’ for more details.
sudo nano /tmp/tmp2KOWbQ :
2019-08-03 18:20:41,154:DEBUG:certbot.log:Exiting abnormally:
File "/usr/local/bin/certbot", line 11, in <module>
sys.exit(main())
File "/usr/local/lib/python2.7/dist-packages/certbot/main.py", line 1351, in main
plugins = plugins_disco.PluginsRegistry.find_all()
File "/usr/local/lib/python2.7/dist-packages/certbot/plugins/disco.py", line 208, in find_all
plugin_ep = PluginEntryPoint(entry_point)
File "/usr/local/lib/python2.7/dist-packages/certbot/plugins/disco.py", line 50, in __init__
self.plugin_cls = entry_point.load()
File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 2323, in load
self.require(*args, **kwargs)
File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 2346, in require
items = working_set.resolve(reqs, env, installer, extras=self.extras)
File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 783, in resolve
raise VersionConflict(dist, req).with_context(dependent_req)
Requirement.parse('cryptography>=2.3'), set(['PyOpenSSL']))
2019-08-03 18:20:41,154:ERROR:certbot.log:An unexpected error occurred:
Looking forward to your kind help.
Marco
