Sudden Error using Certbot NET::ERR_CERT_AUTHORITY_INVALID
I have been installing SSL certificates using cerbot for years now using the same command without issues, lately - I get this problem - Certificate not valid. I have tried different Ubuntu versions, I cannot figure out what is causing it.
My domain is: https://webhook.skolo.online/
I ran this command: sudo certbot --nginx -d webhook.skolo.online
It produced this output: The certificate was installed as usual, I have ran this command many times in the past with other domains without an issue
My web server is (include version): Nginx
The operating system my web server runs on is (include version): Ubuntu 16.04 LTS Xenial
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.31.0
Hi @tatiblockchain
there is no problem visible - see https://check-your-website.server-daten.de/?q=webhook.skolo.online
The certificate is new
CN=webhook.skolo.online
	10.04.2021
	09.07.2021
expires in 90 days	webhook.skolo.online - 1 entry
no chain problems.
Only "problem": You have defined the www subdomain in your DNS.
But your domain has only the non-www domain name. So the www domain name has the wrong certificate, that connection is insecure.
But normally, www isn't used if it is a subdomain.
  • Remove the www CNAME (or)
  • Create a certificate with both domain names
Thank you, i removed the www DNS record and it works perfectly.
