My domain is: modrealms.net (specifically vote.modrealms.net)
I ran this command: certbot-auto --nginx
It produced this output: Asked for comma-delimited list of my domains which are;
My operating system is (include version): Debian 8
My web server is (include version): Nginx 1.6.2
My hosting provider, if applicable, is: OVH dedicated server
Details:
I accidently included a non-ssl subdomain in the list of sites to add to the certificate and then chose to only allow https connections (as part of the original command). This subdomain uses iframes to third party sites and as such cannot be secure. I have since tried to revert this change by;
- Re-executing the command and only selecting the correct subdomains
- Re-executing the command and allowing non-https connections (I figure this does nothing).
- Stop the subdomain listening on port 443 by removing lines from the “nginx/sites-available/vote” config.
My question, what actions could be causing this redirection to https?
Thanks and apologies for any missing information.
