Stuck pending while trying to
infro.trade
Doing wildcard certificate request for *.infro.trade and *.winwinhelp.org
I setup a CNAME which nslookup results in:
_acme-challenge.winwinhelp.org canonical name = _acme-challenge.infro.trade
Custom python script for dns-01
Doing any of the challenge urls always results in status pending even though I have the TXT record with the response.
{'identifier': {'type': 'dns', 'value': 'infro.trade'},
  'status': 'pending',
  'expires': '2025-06-06T17:48:34Z',
  'challenges': [{'type': 'dns-01',
    'url': 'https://acme-v02.api.letsencrypt.org/acme/chall/2176.../5282.../EHjA...',
    'token': 'pgRW....'}],
  'wildcard': True}
Two separate methods to generate the TXT record were used and come back with the same results.
Verification script I ran to ensure I was generating the correct TXT record (I've tried both quoted and unquoted TXT records)
Running the below python script resulted in the reported token length of 43 and the challenge response of uWsKsHpO7hzjOY2nIZD2PStLQoooGJtjkyvlBc7B1Hs
from acme.challenges import DNS01
import josepy
import cryptography.hazmat.primitives.serialization as serialization
with open('account.key', 'rb') as f:
    key = serialization.load_pem_private_key(f.read(), None)
token=josepy.decode_b64jose('pgRW....')
print(len('pgRW....'))
msg = DNS01(token=token)
key = josepy.JWKRSA(key = key)
print(msg.validation(key))
If I try and finalize I obviously get an error {'type': 'urn:ietf:params:acme:error:orderNotReady', 'detail': 'Order\'s status ("pending") is not acceptable for finalization', 'status': 403}
I last ran this notebook in January with the following results:
[{'url': 'https://acme-v02.api.letsencrypt.org/acme/order/2176....35/3454....',
  'result': {'status': 'valid',
   'expires': '2025-01-25T04:23:58Z',
   'identifiers': [{'type': 'dns', 'value': '*.infro.trade'},
    {'type': 'dns', 'value': '*.winwinhelp.org'},
    {'type': 'dns', 'value': 'winwinhelp.org'}],
   'authorizations': ['https://acme-v02.api.letsencrypt.org/acme/authz/2176....5/4623....35',
    'https://acme-v02.api.letsencrypt.org/acme/authz/2176....5/4623....45',
    'https://acme-v02.api.letsencrypt.org/acme/authz/2176....5/4623....55',
    'https://acme-v02.api.letsencrypt.org/acme/authz/2176....5/4623....65'],
   'finalize': 'https://acme-v02.api.letsencrypt.org/acme/finalize/2176..../3454....',
   'certificate': 'https://acme-v02.api.letsencrypt.org/acme/cert/03a5....'}}]
Any other information that needs to be provided?
This indicates you have not triggered a validation attempt for the challenge.
When the validation attempt is triggered, the pending state of the challenge will transition to processing.
See RFC 8555 - Automatic Certificate Management Environment (ACME) Section 7.1.6 Status Changes
Thank you, that let me figure out I needed to send a payload of {} rather than an empty payload...
That is a very common mistake! I have gotten tripped up by that too.
{} will trigger the validation attempt.
An empty payload will poll the endpoint for a status change.
