Stuck on trying to issue a certificate. Error: The client lacks sufficient authorization
I have been trying certbot to issue a certificate, but the challenge keeps failing. I also made a .well-known/acme-challenge available through nginx settings. Nothing seems to be working.
My domain is: posherry.com
I ran this command: sudo certbot certonly --nginx -d posherry.com -d www.posherry.com --dry-run --webroot- path /var/www/html
Failed authorization procedure. posherry.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://posherry.com/.well-known/acme-challenge/PICPsfGsrWq8aNkpnJ9Ms7Kc_g_UlDWQRbKOjaSCCIw: "<!DOCTYPE html>
<html lang="en">
  <head>
    <meta charset="utf-8">
    <meta name="viewport" content="width=device-width,initi"
   Domain: posherry.com
   Type:   unauthorized
   Detail: Invalid response from
   "<!DOCTYPE html>
   <html lang="en">
     <head>
My web server is (include version): nginx/1.14.0
My hosting provider, if applicable, is: DigitalOcean
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): SSH, no control panel
posherry.com.  (insecure)  3574  A     139.59.46.65
posherry.com.  (insecure)  1774  AAAA  2604:a880:400:d0::ab3:1001
Is posherry.com's IPv6 address correct?
Apparently not. just fixed it and it worked like a charm. Thank you so much. You have fixed in minutes what took me an entire day of head scratching and failing. Thank you :smile:
