My domain is: oz1cxp.duckdns.org
I ran this command: "dehydrated -c"
INFO: Using main config file /etc/dehydrated/config
Processing oz1cxp.duckdns.org
- Checking domain name(s) of existing cert... unchanged.
- Checking expire date of existing cert...
- Valid till Feb 6 21:02:38 2022 GMT (Less than 30 days). Renewing!
- Signing domains...
- Generating private key...
- Generating signing request...
- Requesting new certificate order from CA...
- Received 1 authorizations URLs from the CA
- Handling authorization for oz1cxp.duckdns.org
- 1 pending challenge(s)
- Deploying challenge tokens...
- Responding to challenge for oz1cxp.duckdns.org authorization...
- Cleaning challenge tokens...
- Challenge validation has failed
ERROR: Challenge is invalid! (returned: invalid) (result: ["type"] "http-01"
["status"] "invalid"
["error","type"] "urn:ietf:params:acme:error:connection"
["error","detail"] "Fetching http://oz1cxp.duckdns.org/.well-known/acme-challenge/1nGgzpBeATk6J4VQFLxZNmnh2SqnhXGC5kDALvn0s2w: Timeout during connect (likely firewall problem)"
["error","status"] 400
["error"] {"type":"urn:ietf:params:acme:error:connection","detail":"Fetching http://oz1cxp.duckdns.org/.well-known/acme-challenge/1nGgzpBeATk6J4VQFLxZNmnh2SqnhXGC5kDALvn0s2w: Timeout during connect (likely firewall problem)","status":400}
["url"] "https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/1624878878/bEvFxQ"
["token"] "1nGgzpBeATk6J4VQFLxZNmnh2SqnhXGC5kDALvn0s2w"
["validationRecord",0,"url"] "http://oz1cxp.duckdns.org/.well-known/acme-challenge/1nGgzpBeATk6J4VQFLxZNmnh2SqnhXGC5kDALvn0s2w"
["validationRecord",0,"hostname"] "oz1cxp.duckdns.org"
["validationRecord",0,"port"] "80"
["validationRecord",0,"addressesResolved",0] "85.204.132.67"
["validationRecord",0,"addressesResolved"] ["85.204.132.67"]
["validationRecord",0,"addressUsed"] "85.204.132.67"
["validationRecord",0] {"url":"http://oz1cxp.duckdns.org/.well-known/acme-challenge/1nGgzpBeATk6J4VQFLxZNmnh2SqnhXGC5kDALvn0s2w","hostname":"oz1cxp.duckdns.org","port":"80","addressesResolved":["85.204.132.67"],"addressUsed":"85.204.132.67"}
["validationRecord"] [{"url":"http://oz1cxp.duckdns.org/.well-known/acme-challenge/1nGgzpBeATk6J4VQFLxZNmnh2SqnhXGC5kDALvn0s2w","hostname":"oz1cxp.duckdns.org","port":"80","addressesResolved":["85.204.132.67"],"addressUsed":"85.204.132.67"}]
["validated"] "2022-02-07T16:02:33Z")
nginx 1.18.0
debian 11.2
My hosting provider, if applicable, is: myself
no
or certbot-auto --version
if you're using Certbot):
dehydrated 0.7.0
The strange thing is that i can see in the nginx logs, that the first request gets answered with 200:
18.196.102.134 - - [07/Feb/2022:17:02:33 +0100] "GET /.well-known/acme-challenge/1nGgzpBeATk6J4VQFLxZNmnh2SqnhXGC5kDALvn0s2w HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
34.219.64.153 - - [07/Feb/2022:17:02:33 +0100] "GET /.well-known/acme-challenge/1nGgzpBeATk6J4VQFLxZNmnh2SqnhXGC5kDALvn0s2w HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
64.71.144.196 - - [07/Feb/2022:17:27:45 +0100] "GET /.well-known/acme-challenge/1nGgzpBeATk6J4VQFLxZNmnh2SqnhXGC5kDALvn0s2w: HTTP/1.1" 404 125 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0 Safari/605.1.15"
64.71.144.196 - - [07/Feb/2022:17:27:46 +0100] "GET /.well-known/acme-challenge/1nGgzpBeATk6J4VQFLxZNmnh2SqnhXGC5kDALvn0s2w HTTP/1.1" 404 125 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0 Safari/605.1.15"
64.71.144.196 - - [07/Feb/2022:17:27:46 +0100] "GET /.well-known/acme-challenge/1nGgzpBeATk6J4VQFLxZNmnh2SqnhXGC5kDALvn0s2w%22,%22hostname%22:%22oz1cxp.duckdns.org%22,%22port%22:%2280%22,%22addressesResolved%22:%5B%2285.204.132.67%22%5D,%22addressUsed%22:%2285.204.132.67 HTTP/1.1" 404 125 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0 Safari/605.1.15"
What is it, that is happening, I have been using letsencrypt on this server for about 2 years, but now it stopped working.
ps) I am using the test server, as I ran into rate limitting.
