Strange problem with Pebble
I've been developing an ACME client against the staging server, but have switched to testing with Pebble.
When making a new account request to Pebble I get this problem response,
  type: "urn:ietf:params:acme:error:malformed",
  detail: "JWS header parameter 'url' incorrect. Expected \"https://localhost:14000/https://localhost:14000/sign-me-up\", got \"https://localhost:14000/sign-me-up\"",
  status: 400
Pebble expects the url field to be https://localhost:14000/https://localhost:14000/sign-me-up?
This doesn't seem right.
Pebble is run in a container with this command,
"pebble",
"-config",
"/test/config/pebble-config.json",
"-strict",
"-dnsserver",
"10.30.50.3:8053"
pebble-config.json,
  "pebble": {
    "listenAddress": "0.0.0.0:14000",
    "managementListenAddress": "0.0.0.0:15000",
    "certificate": "test/certs/localhost/cert.pem",
    "privateKey": "test/certs/localhost/key.pem",
    "httpPort": 5002,
    "tlsPort": 5001,
    "ocspResponderURL": "",
    "externalAccountBindingRequired": false
Any ideas?
Can you share the contents of pebble-config.json? Not sure if it'll help, but probably a good idea to show it, so others won't ask for it later :stuck_out_tongue:
Pebble reflects the the Request-URI and Host request header when it checks for URL correctness.
You might be sending:
GET https://localhost:14000/sign-me-up HTTP/1.1
Host: localhost:14000
Which, while is technically correct, isn't supported by Pebble.
Thanks. That’s what it was. Request URI
