Still CAA problem
My domain is zignago.com. Need certificate for cda and cda-iniviti
I use IIS 10.
Letsenrypt for windows returns me:
[EROR] Authorization result: invalid
[EROR] ACME server reported:
[EROR] [type] urn:acme:error:dns
[EROR] [detail] DNS problem: query timed out looking up CAA for cda.zignago.com
[EROR] [status] 400
[EROR] Create certificate failed
I create CAA record in DNS. They seem ok. Error still remains…
I don’t know how to solve it anymore…
; <<>> DiG 9.8.2rc1-RedHat-9.8.2-0.62.rc1.el6_9.5 <<>> caa cda.zignago.com @1.1.1.1
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 6995
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;cda.zignago.com. IN CAA
;; ANSWER SECTION:
cda.zignago.com. 2775 IN CAA 0 issue “letsencrypt.org”
;; Query time: 6 msec
;; SERVER: 1.1.1.1#53(1.1.1.1)
;; WHEN: Thu May 10 17:56:33 2018
;; MSG SIZE rcvd: 67
Regards,
Graziano
The dig output you're posting is from 1.1.1.1, while Let's Encrypt uses the authoritative servers for your domain (ns.infuturo.it and ns.iunet.it). Neither of those respond to requests for CAA records (try dig @ns.infuturo.it caa cda.zignago.com to see for yourself). And the lack of response is the problem--Let's Encrypt doesn't need to see a CAA record, they just need to see the authoritative nameserver respond properly when asked for one.
Graphically: http://dnsviz.net/d/cda.zignago.com/dnssec/
Danb35, I’ve tried. It responds me:
; <<>> DiG 9.8.2rc1-RedHat-9.8.2-0.62.rc1.el6_9.5 <<>> @ns.infuturo.it caa cda.zignago.com
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 62920
;; flags: qr aa rd; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 1
;; WARNING: recursion requested but not available
;; ANSWER SECTION:
cda.zignago.com. 3600 IN CAA 0 issue “letsencrypt.org”
;; AUTHORITY SECTION:
zignago.com. 3600 IN NS ns.infuturo.it.
zignago.com. 3600 IN NS ns.iunet.it.
;; ADDITIONAL SECTION:
ns.infuturo.it. 28800 IN A 192.106.1.9
;; Query time: 10 msec
;; SERVER: 192.106.1.9#53(192.106.1.9)
;; WHEN: Fri May 11 16:11:36 2018
;; MSG SIZE rcvd: 134
It seems ok. Or not???
Regards,
Graziano.
Osiris, what does
cda.zignago.com/CAA: No response was received from the server over UDP (tried 8 times). (192.106.1.1, 192.106.1.9, UDP_0_NOEDNS)
mean?
Regards,
Graziano.
Still not working for me. Is it possible that your ISP's nameservers don't respond to DNS requests (or to certain DNS requests) from outside? That would seem like an odd configuration, but it would explain the discrepancy.
Hi @gtartari,
That means your dns servers only answer requests for CAA records via tcp but not udp (at least from my side) and that is clearly wrong.
Using udp:
$ dig @ns.infuturo.it cda.zignago.com caa +short
; <<>> DiG 9.9.7 <<>> @ns.infuturo.it cda.zignago.com caa +short
; (1 server found)
;; connection timed out; no servers could be reached
Using tcp:
$ dig @ns.infuturo.it cda.zignago.com caa +short +tcp
0 issue "letsencrypt.org"
Cheers,
sahsanu
Clear, without doubt.
Regards,
Graziano.
Sahsanu,
now I get this response:
[11:01 Tue May 15 ~]$ dig @ns.infuturo.it cda.zignago.com caa +short
But letsenrypt cannot query the DNS…
[EROR] [detail] DNS problem: SERVFAIL looking up CAA for cda.zignago.com
[EROR] [status] 400
Where is the problem??
Regards,
Graziano.
Hi @gtartari,
I don’t know how are your authoritative name servers configured but it fails to answer for CAA records requests over UDP from some countries (it works fine for every country I tried if I request CAA record over TCP or any other record like A over UDP or TCP).
From SPAIN (FAIL):
$ dig -4 @192.106.1.9 cda.zignago.com caa +notcp +short
; <<>> DiG 9.9.7 <<>> -4 @192.106.1.9 cda.zignago.com caa +notcp +short
; (1 server found)
From US (OK):
From UK (FAIL):
; <<>> DiG 9.11.1 <<>> -4 @192.106.1.9 cda.zignago.com caa +notcp +short
; (1 server found)
From FRANCE Location 1 (FAIL):
; (1 server found)
From FRANCE Location 2 (OK):
From GERMANY (OK):
Using Google DNS public resolver (FAIL):
$ dig -4 @8.8.8.8 cda.zignago.com caa +notcp
; <<>> DiG 9.11.1 <<>> -4 @8.8.8.8 cda.zignago.com caa +notcp
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 34055
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; Query time: 2016 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Tue May 15 11:34:50 CEST 2018
;; MSG SIZE  rcvd: 44
Using Cloudflare DNS public resolver (OK):
$ dig -4 @1.1.1.1 cda.zignago.com caa +notcp +short
Using QUAD DNS public resolver (FAIL):
$ dig -4 @9.9.9.9 cda.zignago.com caa +notcp
; <<>> DiG 9.11.1 <<>> -4 @9.9.9.9 cda.zignago.com caa +notcp
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 2270
; EDNS: version: 0, flags:; udp: 4096
;; Query time: 3023 msec
;; SERVER: 9.9.9.9#53(9.9.9.9)
;; WHEN: Tue May 15 11:35:43 CEST 2018
If you check it using dnsviz you get this problem:
I don’t know what is going on but there is something strange with your Authoritative DNS Servers.
Good luck,
sahsanu
