I’m obfuscating the domain name here because while publicly accessible, this multi-domain server hosts only testing environments for a web application, and I do not wish to have it listed on the internet.
I ran this command: certbot certonly --test-cert --webroot -d machine1.example.com -d env01.example.com -d env02.example.com
And it worked fine.
Then, I ran the exact same command, without the --test-cert flag: certbot certonly --webroot -d machine1.example.com -d env01.example.com -d env02.example.com
And it failed.
Failed authorization procedure. env01.example.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to env01.example.com
Domain: env01.example.com
Type: connection
Detail: Could not connect to env01.example.com
Debian 8 Jessie (Linux machine1 3.16.0-4-amd64 #1 SMP Debian 3.16.39-1 (2016-12-30) x86_64 GNU/Linux)
My web server is (include version): Nginx version: nginx/1.10.2
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): DNS is managed through Godaddy’s web interface.
What I don’t get is why the hell is everything working fine when using staging environment, and some domain fail to validate when trying to generate production certificates.
Every subdomain I provide to certbot for validation has its own web root, and is publicly accessible.
I don’t get what’s going wrong.
Have you tried using a new account on staging? It may be that your existing staging account has some previously validated authorizations that are being reused, preventing the requests from failing like they would if a fresh validation were attempted.
I appreciate your concern, but the domain will also be included in certificate transparency logs and it is quite difficult to debug this sort of problem without knowing the domain
I removed the account for the staging environment and you were right, a previous validation succeeded when I tried to verify only one subdomain probably helped me avoiding the error.
Yeah you’re right, I probably can post them here as well.
I tried to issue certificates for the following domains:
Each t00x subdomain uses the exact same nginx configuration, only the server name and root path or log file path changes accordingly. They all redirect 301 from standard HTTP:80 to HTTPS:443.
The as-105507 subdomain has a different server block configuration, and only supports http on port 80.
Somehow, t006 and as-105507 succeed to verify, as they do not appear in the error output below.
However, every other one fails.
I checked that accessing files under .well-known folder works for every subdomain, and it does.
The “manual” proof is here for each subdomain: http://xxxxx.allsquaregolf.com/.well-known/whoami.html
Failed authorization procedure. t002.allsquaregolf.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to tOO2.allsquaregolf.com, t003.allsquaregolf.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to tOO3.allsquaregolf.com, t001.allsquaregolf.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to tOO1.allsquaregolf.com, t005.allsquaregolf.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to tOO5.allsquaregolf.com, t004.allsquaregolf.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to tOO4.allsquaregolf.com
- If you lose your account credentials, you can recover through
e-mails sent to webmaster@allsquaregolf.com.
Domain: t002.allsquaregolf.com
Type: connection
Detail: Could not connect to tOO2.allsquaregolf.com
Domain: t003.allsquaregolf.com
Type: connection
Detail: Could not connect to tOO3.allsquaregolf.com
Domain: t001.allsquaregolf.com
Type: connection
Detail: Could not connect to tOO1.allsquaregolf.com
Domain: t005.allsquaregolf.com
Type: connection
Detail: Could not connect to tOO5.allsquaregolf.com
Domain: t004.allsquaregolf.com
Type: connection
Detail: Could not connect to tOO4.allsquaregolf.com
Oh man I feel really stupid right now… Thanks for pointing this out!! I actually didn’t notice when testing because I directly used https in order to access my whoami.html test files…
Obviously with wrong redirection that can’t work…
I tried debugging with curl as well, just like you did, but did not notice the O's instead of the 0s… Meh
Thanks guys, everything worked fine after correcting the redirections!
