Can you fill out answers to the other questions in the questionnaire below?
Can you also show us the Apache virtual host(s) involved? And any other SSL-related settings from ssl.conf or httpd.conf or other included files?
The options-ssl-apache.conf file doesn’t do anything on its own. Apache doesn’t look in /etc/letsencrypt/ unless it’s told to. If you use Certbot’s apache installer to configure Apache, it will add an Include directive to use it. If you used certbot certonly, or removed the Include from Apache’s configuration, that file won’t be involved.
Looking at the SSL Labs report for your website, it looks like you’re not using the Certbot Apache configuration – your settings are more secure than it is!
(Certbot’s Apache defaults are based on an older version of Mozilla’s intermediate configuration. They’re still fine, but contain some bottom-priority, mediocre settings that security scanners will warn about and that could be removed.)
Taking a quick look at what the Internet.nl scan says, not everything it says looks necessary or common (though not bad). Copying Mozilla’s current modern or intermediate configuration and ignoring any remaining complaints Internet.nl has would work.
Additionally, SSL Labs reports an issue with how Apache is configured: Your certificate is sent twice, which is incorrect, wastes bandwidth and will make some clients unable to access your website. There’s probably an issue with how SSLCertificateFile and SSLCertificateChainFile are set.
