Scratch that...I see....combined added.
Erroring out farther below....
fred@Fred-DME:/etc/apache2/sites-available$ sudo apachectl -k graceful
apache2: Syntax error on line 225 of /etc/apache2/apache2.conf: Syntax error on line 8 of /etc/apache2/sites-enabled/fredcolclough.com.conf: without matching section
Action '-k graceful' failed.
I haven't changed apache2.conf file...
No. It's complaining about line 8 of the new file. The closing VirtualHost tag is on its own line, right?
Yes, it's a copy of yours... could it be newline? In VI it shows a blue 'M at end of each line.
Get rid of those. They're the silly carriage return (\r) characters I was referring to earlier. I'll bet you're doing this editing from a Windows 10 machine...
They look like this ^M
right?
Yes, Win 10. Using Notepad, then filezilla to upload (w/ root for perms). OK.... that'll take some time, hang in there.
\r\n = Windows
\n = *nix
\r = Apple
Got rid of them...now it's back to failing as before (combined is there):
fred@Fred-DME:/etc/apache2/sites-available$ sudo vi fredcolclough.com.conf
AH00526: Syntax error on line 14 of /etc/apache2/sites-enabled/fredcolclough.com.conf:
CustomLog takes two or three arguments, a file name, a custom log format string or format name, and an optional "env=" or "expr=" clause (see docs)
Hang on.... might be typo.
Grrrr....what am I missing?
AH00526: Syntax error on line 15 of /etc/apache2/sites-enabled/fredcolclough.com.conf:
Invalid command 'SSLEngine', perhaps misspelled or defined by a module not included in the server configuration
One moment... I think there's something else needed.
Here's the whole file again:
<VirtualHost *:443>
ServerName www.fredcolclough.com
SSLEngine on
SSLCertificateFile /etc/ssl/certificate.crt
SSLCertificateKeyFile /etc/ssl/private/privatekey.pem
SSLProtocol all -SSLv2 -SSLv3
SSLCipherSuite ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA
SSLHonorCipherOrder on
SSLCompression off
SSLOptions +StrictRequire
LogFormat "%h %l %u %t "%r" %>s %b "%{Referer}i" "%{User-agent}i"" vhost_combined
LogFormat "%v %h %l %u %t "%r" %>s %b" vhost_common
Redirect permanent / https://fredcolclough.com/
<VirtualHost *:443>
ServerName fredcolclough.com
DocumentRoot /var/www/html/
SSLEngine on
SSLCertificateFile
Put this line right above the first <VirtualHost *:443>
line:
<IfModule mod_ssl.c>
Put this line right below the last </VirtualHost>
line (at the end of the file):
</IfModule>
I updated the text above accordingly.
So I am getting this:
443/tcp closed https
Port 80 and port 443 need to be accessible to the internet.
Fix this and you will move forward
Working on it... thx.
I'm away for a bit. Back later sometime. You should be getting very close.
He had no port 443 vHost. That's what we've been fixing.
The syntax errors are right near those SSLcert entries.... checking the syntax and the 'M's... might just start over and re-copy-paste.
