Quite a bizarre thing, SSL certs works perfectly across the board with an A+ at SSL Labs yet it doesn’t load correctly in Safari or Chrome on iOS when using T-Mobile’s LTE network.
Here’s the Nginx configuration
listen 80;
listen 443 ssl;
listen [::]:443 ssl;
server_name mydomain;
ssl_certificate /etc/letsencrypt/live/mydomain/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/mydomain/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/live/mydomain/fullchain.pem;
ssl_session_timeout 1d;
ssl_session_cache shared:SSL:50m;
ssl_session_tickets off;
ssl_protocols TLSv1.2;
ssl_ciphers EECDH+AESGCM:EECDH+AES;
ssl_ecdh_curve secp384r1;
ssl_prefer_server_ciphers on;
ssl_stapling on;
ssl_stapling_verify on;
add_header Strict-Transport-Security "max-age=15768000; includeSubdomains; preload";
add_header X-Frame-Options DENY;
add_header X-Content-Type-Options nosniff;
if ($ssl_protocol = "") {
rewrite ^ https://$host$request_uri? permanent;
proxy_pass http://127.0.0.1:1337;
proxy_http_version 1.1;
proxy_set_header Connection upgrade;
proxy_set_header Host $host;
location '/.well-known/acme-challenge/' {
default_type "text/plain";
root /home/j/www/mydomain;
Any ideas?
Unless you reveal your domain name, helping you is quite hard.
Could you please clarify the misconfiguration regarding ports? I don’t see it.
The domain is https://critical-mass.network not that it matters.
From what I’ve gathered is that T-mobile’s LTE network is strictly ipv6, but should work via ipv6 as well with the current config right?
nevermind. I thought he misconfig the server by putting 80 and 443 in one config.
Yes, it should.
However, you definitely misconfigured the server.
Please add :port 80 ipv6 on your config, or it wont load on my phone.
(As well on SSL labs)
listen 80;
listen [::]:80;
server_name critical-mass.network;
return 301 https://critical-mass.network$request_uri;
Adding this, still doesn’t pick it up, missing something?
sahsanu
February 28, 2018, 2:11pm
#9
You should review your firewall rules for IPv6 or port forwarding if you are using it.
you have an ipv6 record and it’s not accessible.
T-Mo prefer v6 than v4, so, please check your config.
Thank you
This ought to do it right?
~ » sudo ip6tables -L j@criticalmass
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all anywhere anywhere
REJECT all localhost anywhere reject-with icmp6-port-unreachable
ACCEPT ipv6-icmp anywhere anywhere
ACCEPT tcp anywhere anywhere tcp dpt:http state NEW
ACCEPT tcp anywhere anywhere tcp dpt:https state NEW
ACCEPT all anywhere anywhere state RELATED,ESTABLISHED
LOG all anywhere anywhere limit: avg 5/min burst 5 LOG level debug prefix "ip6tables_INPUT_denied: "
REJECT all anywhere anywhere reject-with icmp6-port-unreachable
Chain FORWARD (policy ACCEPT)
LOG all anywhere anywhere limit: avg 5/min burst 5 LOG level debug prefix "ip6tables_FORWARD_denied: "
Chain OUTPUT (policy ACCEPT)
will the proxy pass cause issues with nginx?
sahsanu
February 28, 2018, 2:49pm
#12
That rule doesn’t make much sense to me, especially if you are using proxy pass.
system
closed
March 30, 2018, 2:49pm
#13
