SSL Renew - Heroku ACM - Domain considered unsafe
Hi everyone,
We are currently using Heroku ACM in order to automatically emit/renew SSL certificates for our web service. It is now time to get our first renew but it is failing.
Indeed, Heroku Dashboard give us the following error : “Automated Certificate Management Failing - Domain considered unsafe”.
According to Heroku doc (http://www.google.com/safebrowsing/diagnostic?site=http://yourdomainhere.com/), SSL renew use Google’s Safe Browsing API to ensure domain before renewing certificate, however all seems O.K for our domains. See :
http://www.google.com/safebrowsing/diagnostic?site=lecomptoirdespharmacies.fr
http://www.google.com/safebrowsing/diagnostic?site=www.lecomptoirdespharmacies.fr
We created a Ticket on Heroku support team which tell us that they built their ACM on top of Let’s Encrypt service. Following their advices, we write this topic here as you may help us to get our domain cleared.
Should we use the link provided here to unstuck the Let’s Encrypt / Google’s Safe Browsing verification process ? My domain was considered an unsafe domain by a third-party API
Thanks in advance for your help !
Yours faithfully,
LCDP
Technical Details :
Do not know which command is executed by Heroku ACM.
Our business Web Server uses Play Framework in version 2.3.
Don not know which server is used to ensure SSL + Web Service on Heroku side.
Do not know
Heroku
No
Heroku control panel, current version
Do not know
Let's Encrypt no longer uses Safe Browsing.
Does Heroku give you access to the real error message, if any, from Let's Encrypt, or other debug information like the order URL?
Edited to add: By the way, you got a certificate for lecomptoirdespharmacies.fr (without www.lecomptoirdespharmacies.fr) a week ago.
Oh… This is a very interesting answer, thanks !
Unfortunately, we do not have any information about the error apart from the “unsafe” error message.
Mhhhh… So maybe Heroku successfully renew the certificate but their system failed to recognize it !
I am going to reply on Heroku ticket with link to this thread.
Hi all,
We just solved our problem after Heroku Support team technical answer.
Renewal issue came from one of our custom domain (lecomptoirdespharmacies.fr) which was pointing to OVH web server (it redirect to ‘www’ subsomain) instead of pointing to Heroku custom alias.
This particular redirection was necessary due to the fact that OVH do not permit alias on root domain.
Removing this custom endpoint solved our certificate renewal issue !
Thanks for your indications and we hope that this thread will help someone in the future.
Yours faithfully,
Le Comptoir Des Pharmacies
