https://advancedaestheticsmn.com fails to work on many Safari browsers but shows up just fine on chrome and other devices.
Thanks for the help
Thanks for the help
your website uses only Tls.1.2
So
Safari 5.1.9 / OS X 10.6.8
Safari 6.0.4 / OS X 10.8.4
can't use the site.
So Does 1.3 fix this?
May I ask where you got the results? Where can I run this test? Thank you
Safari 5.1.9 / OS X 10.6.8 and Safari 6.0.4 / OS X 10.8.4 support only Tls.1.0. So if you deactivate Tls.1.0 and Tls.1.1, these Safari - users can't use your site.
But:
https://discussions.apple.com/thread/5128209
No version of Safari 6.x goes above TLS 1.0, which of course is a travesty and [insert expletive here] of Apple. Obviously, this should have been addressed.
And the conclusion:
So if I am on Safari 6.1.6, I'm dead in the water with TLS 1.1 or 1.2. So I must use Google Chrome instead of Safari.
PS: IE8 - IE10 with Windows 7: There is a manual setting to activate Tls.1.2. But it looks that Safari hasn't such an option.
So these users should install Chrome. Since 2018-06-30, Tls.1.0 is forbidden (Payment Card Industry Security Standards Council - PCI), a lot of websites remove Tls.1.0. Sample:
So it's ok if you don't use Tls.1.0. These users should update their browser.
