mail.gazelkin.ru
wacs.exe --target manual --host mail.gazelkin.ru,exc.gazelkin.ru,autodiscover.gazelkin.ru --store centralssl --centralsslstore "C:\Central SSL" --installation iis,script --installationsiteid 1 --script "./Scripts/ImportExchange.ps1" --scriptparameters "'{CertThumbprint}' 'IIS,SMTP,IMAP' 1 '{CacheFile}' '{CachePassword}' '{CertFriendlyName}'"
A simple Windows ACMEv2 client (WACS)
Software version 2.1.10.896 (RELEASE, PLUGGABLE)
ACME server https://acme-v02.api.letsencrypt.org/
IIS version 10.0
Running with administrator credentials
Scheduled task is disabled
Scheduled task exists but does not look healthy
Please report issues at GitHub - win-acme/win-acme: A simple ACME client for Windows (for use with Let's Encrypt et al.)
Running in mode: Unattended
Target generated using plugin Manual: mail.gazelkin.ru and 2 alternatives
Unable to decrypt configuration value, may have been written by a different machine.
Overwriting previously created renewal[exc.gazelkin.ru] Authorizing...
[exc.gazelkin.ru] Authorizing using http-01 validation (SelfHosting)
[exc.gazelkin.ru] Authorization result: invalid
[exc.gazelkin.ru] {
"type": "urn:ietf:params:acme:error:unauthorized",
"detail": "Invalid response from https://exc.gazelkin.ru/.well-known/acme-challenge/_ncbQ8TX5xtW38Y_AD_GXmV4fuo9RnJBDXHneVwaRkw [77.243.83.103]: 404",
"status": 403
Create certificate failed: [exc.gazelkin.ru] Validation failed
IIS 10
Windows 2019
Exchange 2019
I created the file manually and it is available https://exc.gazelkin.ru/.well-known/acme-challenge/va
whats wrong?
