kohanyim.com
curl -Ii https://kohayim.com/.well-known/acme-challenge/Test_File-1234
curl: (6) Could not resolve host: kohayim.com
nginx 1.20.2
pfSense
2.6.0-RELEASE (amd64)
built on Mon Jan 31 19:57:53 UTC 2022
FreeBSD 12.3-STABLE
This is a PC Build
NOIP
Yes
no. pfSense administration web gui
or certbot-auto --version
if you're using Certbot):
Not using
Moved from the Netgate SG-2100 to a PC Build, was able to import the Cert but, it will be expiring next month on the 8th, so I'm trying to establish the account on again with no success.
I'm able to do this:
curl http://kohanyim.com/404
<html>
<head><title>301 Moved Permanently</title></head>
<body>
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx</center>
</body>
</html>
hangs on this:
curl https://kohanyim.com/404
and
curl -Iv https://kohanyim.com/404
* Trying 67.0.9.244:443...
Get feed back on this:
curl -Iv http://kohanyim.com/404
* Trying 67.0.9.244:80...
* Connected to kohanyim.com (67.0.9.244) port 80 (#0)
> HEAD /404 HTTP/1.1
> Host: kohanyim.com
> User-Agent: curl/7.81.0
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 301 Moved Permanently
< Server: nginx
Server: nginx
< Date: Wed, 06 Jul 2022 04:38:03 GMT
< Content-Type: text/html
< Content-Length: 162
Content-Length: 162
< Connection: keep-alive
< Location: https://kohanyim.com:8000/404
< X-Frame-Options: SAMEORIGIN
* Connection #0 to host kohanyim.com left intact
I need help solving this,
Thanks!....
