Hello,
My domain is: http://ottawaspecial.events
I ran this command: sudo /usr/local/bin/certbot-auto certonly --apache
` - Congratulations! Your certificate and chain have been saved at:`
/etc/letsencrypt/live/ottawaspecial.events/fullchain.pem
/etc/letsencrypt/live/ottawaspecial.events/privkey.pem
Your cert will expire on 2020-03-06. To obtain a new or tweaked
version of this certificate in the future, simply run certbot-auto
again. To non-interactively renew all of your certificates, run
“certbot-auto renew”
My web server is (include version): apache
The operating system my web server runs on is (include version): debian 8
My hosting provider, if applicable, is: ovh
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): current certbot version
Here is my current vhosts file:
<IfModule mod_ssl.c>
<VirtualHost _default_:443>
DocumentRoot /var/www/newsite
ServerName ottawaspecial.events
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/ottawaspecial.events/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/ottawaspecial.events/privkey.pem
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
BrowserMatch "MSIE [2-6]" \
nokeepalive ssl-unclean-shutdown \
downgrade-1.0 force-response-1.0
BrowserMatch "MSIE [17-9]" ssl-unclean-shutdown
</VirtualHost>
when i create the symlink the hosts file, Apache will not accept the configuration or start the web server.
if the symlink is removed, the server will start properly.
