SSL issue with itflow
My domain is: portal.nerdnetworkgroup.com
I ran this command: sudo certbot --apache -d portal.nerdnetworkgroup.com
Requesting a certificate for portal.nerdnetworkgroup.com
Domain: portal.nerdnetworkgroup.com
Detail: 2a02:4780:1:1245:0:3155:137:6: Invalid response from http://portal.nerdnetworkgroup.com/.well-known/acme-challenge/D2ATg-ElgAdpn3nb1yhIf1NoGDlgAbpyymVo4PHx3Mg: 404
My web server is (include version): Server version: Apache/2.4.58 (Ubuntu)
Server built: 2025-04-03T14:36:49
The operating system my web server runs on is (include version): Ubuntu 24.04
My hosting provider, if applicable, is: Hostinger is where my domain is hosted
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):no im using my local onsite servers console
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
Hello @lgice348 and welcome. :slightly_smiling_face:
Here is some supplemental information.
HTTP Request redirects to HTTPS.
$ curl -Ii http://portal.nerdnetworkgroup.com
Connection: Keep-Alive
Keep-Alive: timeout=5, max=100
date: Thu, 10 Apr 2025 17:51:12 GMT
server: LiteSpeed
platform: hostinger
panel: hpanel
content-security-policy: upgrade-insecure-requests
HTTPS Request redirects to an IPv4 Address.
$ curl -Ii https://portal.nerdnetworkgroup.com/
HTTP/2 301
date: Thu, 10 Apr 2025 17:51:19 GMT
server: LiteSpeed
platform: hostinger
panel: hpanel
alt-svc: h3=":443"; ma=2592000, h3-29=":443"; ma=2592000, h3-Q050=":443"; ma=2592000, h3-Q046=":443"; ma=2592000, h3-Q043=":443"; ma=2592000, quic=":443"; ma=2592000; v="43,46"
You need to review the DNS for your domain. You can see from Bruce's info that a LiteSpeed server is replying to requests rather than your Apache
We often see this with new Hostinger setups.
Usually we see just the IPv6 "wrong" but both your IPv4 A record and IPv6 AAAA record in your DNS are wrong.
See Hostinger article here for further info: How to manage AAAA records | Hostinger Help Center
so im a total novice when it comes to domain names and ssl certs clearly i have realize that knowledge gap :slight_smile: so the normal nerdnetworkgroup.com point to a website hosted on hostinger but i wanted to setup a subdomain ie portal.nerdnetworkgroup.com to point to my hosted webapp on my server hosted locally so im not sure exactly how those dns records would need to be setup i can share those if that would help
Those are good questions for Hostinger support :slight_smile: Once you can connect to your portal subdomain and your Apache server using HTTP and a browser then try to get a certificate.
you can check what the Internet visible IP Address are with:
curl -4 ifconfig.me
curl -6 ifconfig.me
and/or
curl -4 ifconfig.co
curl -6 ifconfig.co
and/or
curl -4 ifconfig.io
curl -6 ifconfig.io
And then adjust your DNS A Records and AAAA Records (if any) to match.
Awesome thank you so much for the help but i got it working after looking up the DNS records and fixing them!
