SSL for main and sub domain
My domain is: https://www.effectivehealings.com/ & https://hindi.effectivehealings.com/
My web server is (include version): Lunar Pages
We are looking to integrate paid SSL, right now we are working on free SSL, please guide us how can we integrate SSL from letsencrypt for the main and sub domain , do we have to buy two seperate SSL’s for them.
Hi @effectivehealings
please start with some basics:
Then select a client:
You can create one certificate with all domain- and subdomain names. Or you create one certificate per domain name. Both is possible.
It's more a question of your vHost configuration. Do you have root access? If no, your options are limited.
PS: Checking your domain you use already a cPanel certificate ( https://check-your-website.server-daten.de/?q=effectivehealings.com#ct-logs ):
cPanel, Inc. Certification Authority 2019-08-12 2019-11-10 hindi.effectivehealings.com, www.hindi.effectivehealings.com - 2 entries
cPanel, Inc. Certification Authority 2019-07-07 2019-10-05 effectivehealings.com, effectivehealings.showboatentertainment.com, mail.effectivehealings.com, www.effectivehealings.com, www.effectivehealings.showboatentertainment.com - 5 entries
And your cPanel configuration is good, all cPanel ports are secure.
	2083
	cPanel (https)
	open
	https://effectivehealings.com:2083/
Http-Status: 200
	Certificate is valid
	2086
	WHM (http)
	2087
	WHM SSL
	open
	https://effectivehealings.com:2087/
Http-Status: 200
	2089
	cPanel Licensing
	2095
	cPanel Webmail (http)
	2096
	cPanel Webmail (https)
	open
	https://effectivehealings.com:2096/
Http-Status: 200
Your domain uses the same valid certificate:
CN=effectivehealings.com
	07.07.2019
	06.10.2019
expires in 52 days	effectivehealings.com,
So you don't need an own client. Looks like all is done.
Here is link of tutorial if you have cpanel to manage SSL
https://www.hostplax.com/client/index.php?rp=/knowledgebase/4/How-to-install-auto-SSL-on-Linux-shared-hosting.html
