SSL for LXD Container websites
My domain is: streamingworld.us
sudo certbot certonly --standalone -d lpc1.streamingworld.us --non-interactive --agree-tos --email rayjender@gmail.com --http-01-port=8888
My web server is (include version): nginx 1.10.3
The operating system my web server runs on is (include version): Ubuntu 16.04
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.28.0
I have multiple LXD containers with websites. I also have a container running haproxy (10.106.37.15). I port forward (iptables) ports 80, 443 and 8888 from the host to the haproxy container. lpc1 is a container 10.106.37.94. I can ping lpc1.streamingworld.us
from external internet.
Running the following command:
root@HAPROXY:/etc/ssl# sudo certbot certonly --standalone -d lpc1.streamingworld.us --non-interactive --agree-tos --email rayjender@gmail.com --http-01-port=8888
http-01 challenge for lpc1.streamingworld.us
Waiting for verification…
Failed authorization procedure. lpc1.streamingworld.us (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://lpc1.streamingworld.us/.well-known/acme-challenge/Clc71dZDKioynV4OC5oWgEKxSfXkCngbgMyRs5Eo-bw: Connection refused
    Domain: lpc1.streamingworld.us
    Type: connection
    Detail: Fetching
    Connection refused
On the face of it, the error seems to indicate that your public IP address (23.239.31.177) does not actually have port 80 forwarded to your HAProxy container…
I have this port forwarding active 10.106.37.15 is the haproxy container:
sudo iptables -t nat -I PREROUTING -i eth0 -p TCP -d 23.239.31.177/32 --dport 443 -j DNAT --to-destination 10.106.37.15:443
sudo iptables -t nat -I PREROUTING -i eth0 -p TCP -d 23.239.31.177/32 --dport 80 -j DNAT --to-destination 10.106.37.15:80
sudo iptables -t nat -I PREROUTING -i eth0 -p TCP -d 23.239.31.177/32 --dport 8888 -j DNAT --to-destination 10.106.37.15:8888
Unfortunately it doesn’t work:
$ curl -X GET -I 23.239.31.177
curl: (7) Failed to connect to 23.239.31.177 port 80: Connection refused
If you run this from your LXD host, does it work?
curl -X GET -I 10.106.37.15:80
So I think I have everything fixed as far as configuration goes. I can access the website in the container using https. However, I have an iFrame within the index.html page that will not connects.
The iFrame src is:
See the image for network headers:
Hi @rayj00
I see your http and https. But your http + /.well-known/acme-challenge has a http status 503 (checked with https://check-your-website.server-daten.de/?q=lpc1.streamingworld.us ):
23.239.31.177 200 0.280 H
https://lpc1.streamingworld.us/
23.239.31.177 200 2.700 B
http://lpc1.streamingworld.us/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
23.239.31.177 503 3.293 S
Service Unavailable
Why is there a 503?
Looks like you have fixed the problem. There is a recheck of your domain
CN=lpc1.streamingworld.us
	27.02.2019
	28.05.2019
expires in 90 days	lpc1.streamingworld.us - 1 entry
and the Letsencrypt certificate is new.
