SSL error any help?
My domain is: souqsquare.com
I think this is my error:
souqsquare.com:Verify error:179.61.246.246: Invalid response from http://souqsquare.com/.well-known/acme-challenge/yK6UTpsZCBt_OrUzX7qp2w0MwFxwdzMTeromkbhBMjI: 404
/root/.acme.sh/acme.sh --issue -d souqsquare.com -d www.souqsquare.com --cert-file /etc/letsencrypt/live/www.rmronsol.com/cert.pem --key-file /etc/letsencrypt/live/souqsquare.com/privkey.pem --fullchain-file /etc/letsencrypt/live/souqsquare.com/fullchain.pem -w /home/souqsquare.com/public_html --server letsencrypt --force --debug
[Sun 29 Jan 2023 05:03:25 PM UTC] Selected server: https://acme-v02.api.letsencrypt.org/directory
[Sun 29 Jan 2023 05:03:25 PM UTC] Lets find script dir.
[Sun 29 Jan 2023 05:03:25 PM UTC] _SCRIPT_='/root/.acme.sh/acme.sh'
[Sun 29 Jan 2023 05:03:25 PM UTC] _script='/root/.acme.sh/acme.sh'
[Sun 29 Jan 2023 05:03:25 PM UTC] _script_home='/root/.acme.sh'
[Sun 29 Jan 2023 05:03:25 PM UTC] Using config home:/root/.acme.sh
https://github.com/acmesh-official/acme.sh
v3.0.5
[Sun 29 Jan 2023 05:03:25 PM UTC] Using server: https://acme-v02.api.letsencrypt.org/directory
[Sun 29 Jan 2023 05:03:25 PM UTC] Running cmd: issue
[Sun 29 Jan 2023 05:03:25 PM UTC] _main_domain='souqsquare.com'
[Sun 29 Jan 2023 05:03:26 PM UTC] _alt_domains='www.souqsquare.com'
[Sun 29 Jan 2023 05:03:26 PM UTC] Using config home:/root/.acme.sh
[Sun 29 Jan 2023 05:03:26 PM UTC] ACME_DIRECTORY='https://acme-v02.api.letsencrypt.org/directory'
[Sun 29 Jan 2023 05:03:26 PM UTC] DOMAIN_PATH='/root/.acme.sh/souqsquare.com'
[Sun 29 Jan 2023 05:03:26 PM UTC] Le_NextRenewTime
[Sun 29 Jan 2023 05:03:26 PM UTC] Using ACME_DIRECTORY: https://acme-v02.api.letsencrypt.org/directory
[Sun 29 Jan 2023 05:03:26 PM UTC] _init api for server: https://acme-v02.api.letsencrypt.org/directory
[Sun 29 Jan 2023 05:03:26 PM UTC] GET
[Sun 29 Jan 2023 05:03:26 PM UTC] url='https://acme-v02.api.letsencrypt.org/directory'
[Sun 29 Jan 2023 05:03:26 PM UTC] timeout=
[Sun 29 Jan 2023 05:03:26 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Sun 29 Jan 2023 05:03:26 PM UTC] ret='0'
[Sun 29 Jan 2023 05:03:27 PM UTC] ACME_KEY_CHANGE='https://acme-v02.api.letsencrypt.org/acme/key-change'
[Sun 29 Jan 2023 05:03:27 PM UTC] ACME_NEW_AUTHZ
[Sun 29 Jan 2023 05:03:27 PM UTC] ACME_NEW_ORDER='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Sun 29 Jan 2023 05:03:27 PM UTC] ACME_NEW_ACCOUNT='https://acme-v02.api.letsencrypt.org/acme/new-acct'
[Sun 29 Jan 2023 05:03:27 PM UTC] ACME_REVOKE_CERT='https://acme-v02.api.letsencrypt.org/acme/revoke-cert'
[Sun 29 Jan 2023 05:03:27 PM UTC] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.3-September-21-2022.pdf'
[Sun 29 Jan 2023 05:03:27 PM UTC] ACME_NEW_NONCE='https://acme-v02.api.letsencrypt.org/acme/new-nonce'
[Sun 29 Jan 2023 05:03:27 PM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Sun 29 Jan 2023 05:03:27 PM UTC] _on_before_issue
[Sun 29 Jan 2023 05:03:27 PM UTC] _chk_main_domain='souqsquare.com'
[Sun 29 Jan 2023 05:03:27 PM UTC] _chk_alt_domains='www.souqsquare.com'
[Sun 29 Jan 2023 05:03:27 PM UTC] Le_LocalAddress
[Sun 29 Jan 2023 05:03:27 PM UTC] d='souqsquare.com'
[Sun 29 Jan 2023 05:03:27 PM UTC] Check for domain='souqsquare.com'
[Sun 29 Jan 2023 05:03:27 PM UTC] _currentRoot='/home/souqsquare.com/public_html'
[Sun 29 Jan 2023 05:03:27 PM UTC] d='www.souqsquare.com'
[Sun 29 Jan 2023 05:03:27 PM UTC] Check for domain='www.souqsquare.com'
[Sun 29 Jan 2023 05:03:27 PM UTC] _saved_account_key_hash is not changed, skip register account.
[Sun 29 Jan 2023 05:03:27 PM UTC] Read key length:2048
[Sun 29 Jan 2023 05:03:27 PM UTC] _createcsr
[Sun 29 Jan 2023 05:03:28 PM UTC] Multi domain='DNS:souqsquare.com,DNS:www.souqsquare.com'
[Sun 29 Jan 2023 05:03:28 PM UTC] Getting domain auth token for each domain
[Sun 29 Jan 2023 05:03:28 PM UTC] d='www.souqsquare.com'
[Sun 29 Jan 2023 05:03:28 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Sun 29 Jan 2023 05:03:28 PM UTC] payload='{"identifiers": [{"type":"dns","value":"souqsquare.com"},{"type":"dns","value":"www.souqsquare.com"}]}'
[Sun 29 Jan 2023 05:03:28 PM UTC] RSA key
[Sun 29 Jan 2023 05:03:28 PM UTC] HEAD
[Sun 29 Jan 2023 05:03:28 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/new-nonce'
[Sun 29 Jan 2023 05:03:28 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g -I '
[Sun 29 Jan 2023 05:03:29 PM UTC] _ret='0'
[Sun 29 Jan 2023 05:03:29 PM UTC] POST
[Sun 29 Jan 2023 05:03:29 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Sun 29 Jan 2023 05:03:29 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Sun 29 Jan 2023 05:03:30 PM UTC] code='201'
[Sun 29 Jan 2023 05:03:30 PM UTC] Le_LinkOrder='https://acme-v02.api.letsencrypt.org/acme/order/811229737/161713628117'
[Sun 29 Jan 2023 05:03:30 PM UTC] Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/811229737/161713628117'
[Sun 29 Jan 2023 05:03:30 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/authz-v3/199207499867'
[Sun 29 Jan 2023 05:03:30 PM UTC] payload
[Sun 29 Jan 2023 05:03:30 PM UTC] POST
[Sun 29 Jan 2023 05:03:30 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/authz-v3/199207499867'
[Sun 29 Jan 2023 05:03:30 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Sun 29 Jan 2023 05:03:30 PM UTC] _ret='0'
[Sun 29 Jan 2023 05:03:30 PM UTC] code='200'
[Sun 29 Jan 2023 05:03:31 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/authz-v3/199207499877'
[Sun 29 Jan 2023 05:03:31 PM UTC] payload
[Sun 29 Jan 2023 05:03:31 PM UTC] POST
[Sun 29 Jan 2023 05:03:31 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/authz-v3/199207499877'
[Sun 29 Jan 2023 05:03:31 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Sun 29 Jan 2023 05:03:31 PM UTC] _ret='0'
[Sun 29 Jan 2023 05:03:31 PM UTC] code='200'
[Sun 29 Jan 2023 05:03:31 PM UTC] d='souqsquare.com'
[Sun 29 Jan 2023 05:03:31 PM UTC] Getting webroot for domain='souqsquare.com'
[Sun 29 Jan 2023 05:03:31 PM UTC] _w='/home/souqsquare.com/public_html'
[Sun 29 Jan 2023 05:03:31 PM UTC] _currentRoot='/home/souqsquare.com/public_html'
[Sun 29 Jan 2023 05:03:32 PM UTC] entry='"type":"http-01","status":"pending","url":"https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499867/M3pMbQ","token":"yK6UTpsZCBt_OrUzX7qp2w0MwFxwdzMTeromkbhBMjI"'
[Sun 29 Jan 2023 05:03:32 PM UTC] token='yK6UTpsZCBt_OrUzX7qp2w0MwFxwdzMTeromkbhBMjI'
[Sun 29 Jan 2023 05:03:32 PM UTC] uri='https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499867/M3pMbQ'
[Sun 29 Jan 2023 05:03:32 PM UTC] keyauthorization='yK6UTpsZCBt_OrUzX7qp2w0MwFxwdzMTeromkbhBMjI.hhz0tIxHY7AQ-6I6VOajFE-foRQMYJ5qnj7ECzrgfHE'
[Sun 29 Jan 2023 05:03:32 PM UTC] dvlist='souqsquare.com#yK6UTpsZCBt_OrUzX7qp2w0MwFxwdzMTeromkbhBMjI.hhz0tIxHY7AQ-6I6VOajFE-foRQMYJ5qnj7ECzrgfHE#https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499867/M3pMbQ#http-01#/home/souqsquare.com/public_html'
[Sun 29 Jan 2023 05:03:32 PM UTC] d='www.souqsquare.com'
[Sun 29 Jan 2023 05:03:32 PM UTC] Getting webroot for domain='www.souqsquare.com'
[Sun 29 Jan 2023 05:03:32 PM UTC] _w='/home/souqsquare.com/public_html'
[Sun 29 Jan 2023 05:03:32 PM UTC] _currentRoot='/home/souqsquare.com/public_html'
[Sun 29 Jan 2023 05:03:32 PM UTC] entry='"type":"http-01","status":"pending","url":"https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499877/tc6dlA","token":"U4GM-LGd8UPTtes4XGhTv23FlhIh4pHMFveBECE3g20"'
[Sun 29 Jan 2023 05:03:32 PM UTC] token='U4GM-LGd8UPTtes4XGhTv23FlhIh4pHMFveBECE3g20'
[Sun 29 Jan 2023 05:03:32 PM UTC] uri='https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499877/tc6dlA'
[Sun 29 Jan 2023 05:03:32 PM UTC] keyauthorization='U4GM-LGd8UPTtes4XGhTv23FlhIh4pHMFveBECE3g20.hhz0tIxHY7AQ-6I6VOajFE-foRQMYJ5qnj7ECzrgfHE'
[Sun 29 Jan 2023 05:03:32 PM UTC] dvlist='www.souqsquare.com#U4GM-LGd8UPTtes4XGhTv23FlhIh4pHMFveBECE3g20.hhz0tIxHY7AQ-6I6VOajFE-foRQMYJ5qnj7ECzrgfHE#https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499877/tc6dlA#http-01#/home/souqsquare.com/public_html'
[Sun 29 Jan 2023 05:03:32 PM UTC] vlist='souqsquare.com#yK6UTpsZCBt_OrUzX7qp2w0MwFxwdzMTeromkbhBMjI.hhz0tIxHY7AQ-6I6VOajFE-foRQMYJ5qnj7ECzrgfHE#https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499867/M3pMbQ#http-01#/home/souqsquare.com/public_html,www.souqsquare.com#U4GM-LGd8UPTtes4XGhTv23FlhIh4pHMFveBECE3g20.hhz0tIxHY7AQ-6I6VOajFE-foRQMYJ5qnj7ECzrgfHE#https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499877/tc6dlA#http-01#/home/souqsquare.com/public_html,'
[Sun 29 Jan 2023 05:03:32 PM UTC] d='souqsquare.com'
[Sun 29 Jan 2023 05:03:32 PM UTC] ok, let's start to verify
[Sun 29 Jan 2023 05:03:32 PM UTC] Verifying: souqsquare.com
[Sun 29 Jan 2023 05:03:32 PM UTC] wellknown_path='/home/souqsquare.com/public_html/.well-known/acme-challenge'
[Sun 29 Jan 2023 05:03:32 PM UTC] writing token:yK6UTpsZCBt_OrUzX7qp2w0MwFxwdzMTeromkbhBMjI to /home/souqsquare.com/public_html/.well-known/acme-challenge/yK6UTpsZCBt_OrUzX7qp2w0MwFxwdzMTeromkbhBMjI
[Sun 29 Jan 2023 05:03:32 PM UTC] Changing owner/group of .well-known to souqs6785:nogroup
[Sun 29 Jan 2023 05:03:32 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499867/M3pMbQ'
[Sun 29 Jan 2023 05:03:32 PM UTC] payload='{}'
[Sun 29 Jan 2023 05:03:33 PM UTC] POST
[Sun 29 Jan 2023 05:03:33 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499867/M3pMbQ'
[Sun 29 Jan 2023 05:03:33 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Sun 29 Jan 2023 05:03:33 PM UTC] _ret='0'
[Sun 29 Jan 2023 05:03:33 PM UTC] code='200'
[Sun 29 Jan 2023 05:03:33 PM UTC] trigger validation code: 200
[Sun 29 Jan 2023 05:03:33 PM UTC] Pending, The CA is processing your order, please just wait. (1/30)
[Sun 29 Jan 2023 05:03:33 PM UTC] sleep 2 secs to verify again
[Sun 29 Jan 2023 05:03:36 PM UTC] checking
[Sun 29 Jan 2023 05:03:36 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499867/M3pMbQ'
[Sun 29 Jan 2023 05:03:36 PM UTC] payload
[Sun 29 Jan 2023 05:03:36 PM UTC] POST
[Sun 29 Jan 2023 05:03:36 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499867/M3pMbQ'
[Sun 29 Jan 2023 05:03:36 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Sun 29 Jan 2023 05:03:37 PM UTC] _ret='0'
[Sun 29 Jan 2023 05:03:37 PM UTC] code='200'
[Sun 29 Jan 2023 05:03:37 PM UTC] **souqsquare.com:Verify error:179.61.246.246: Invalid response from http://souqsquare.com/.well-known/acme-challenge/yK6UTpsZCBt_OrUzX7qp2w0MwFxwdzMTeromkbhBMjI: 404**
[Sun 29 Jan 2023 05:03:37 PM UTC] Debug: get token url.
[Sun 29 Jan 2023 05:03:37 PM UTC] GET
[Sun 29 Jan 2023 05:03:37 PM UTC] url='http://souqsquare.com/.well-known/acme-challenge/yK6UTpsZCBt_OrUzX7qp2w0MwFxwdzMTeromkbhBMjI'
[Sun 29 Jan 2023 05:03:37 PM UTC] timeout=1
[Sun 29 Jan 2023 05:03:37 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g --connect-timeout 1'
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL was not found on this server.</p>
<hr>
<address>Apache/2.4.41 (Ubuntu) Server at souqsquare.com Port 80</address>
</body></html>
[Sun 29 Jan 2023 05:03:37 PM UTC] ret='0'
[Sun 29 Jan 2023 05:03:37 PM UTC] Debugging, skip removing: /home/souqsquare.com/public_html/.well-known/acme-challenge/yK6UTpsZCBt_OrUzX7qp2w0MwFxwdzMTeromkbhBMjI
[Sun 29 Jan 2023 05:03:37 PM UTC] pid
[Sun 29 Jan 2023 05:03:37 PM UTC] No need to restore nginx, skip.
[Sun 29 Jan 2023 05:03:37 PM UTC] _clearupdns
[Sun 29 Jan 2023 05:03:37 PM UTC] dns_entries
[Sun 29 Jan 2023 05:03:37 PM UTC] skip dns.
[Sun 29 Jan 2023 05:03:37 PM UTC] _on_issue_err
[Sun 29 Jan 2023 05:03:37 PM UTC] **Please add '--debug' or '--log' to check more details.**
[Sun 29 Jan 2023 05:03:37 PM UTC] **See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh**
[Sun 29 Jan 2023 05:03:38 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499867/M3pMbQ'
[Sun 29 Jan 2023 05:03:38 PM UTC] payload='{}'
[Sun 29 Jan 2023 05:03:38 PM UTC] POST
[Sun 29 Jan 2023 05:03:38 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499867/M3pMbQ'
[Sun 29 Jan 2023 05:03:38 PM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header -L -g '
[Sun 29 Jan 2023 05:03:38 PM UTC] _ret='0'
[Sun 29 Jan 2023 05:03:38 PM UTC] code='400'
[Sun 29 Jan 2023 05:03:38 PM UTC] url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499877/tc6dlA'
[Sun 29 Jan 2023 05:03:38 PM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/199207499877/tc6dlA'
[Sun 29 Jan 2023 05:03:39 PM UTC] _ret='0'
[Sun 29 Jan 2023 05:03:39 PM UTC] code='200'
[Sun 29 Jan 2023 05:03:39 PM UTC] Diagnosis versions:
openssl:openssl
OpenSSL 1.1.1f 31 Mar 2020
apache:
apache doesn't exist.
nginx:
nginx doesn't exist.
socat:
socat by Gerhard Rieger and contributors - see www.dest-unreach.org
socat version 1.7.3.3 on Oct 26 2019 17:42:04
running on Linux version #1 SMP Tue Aug 25 11:59:26 MSK 2020, release 5.4.0, machine x86_64
features:
#define WITH_STDIO 1
#define WITH_FDNUM 1
#define WITH_FILE 1
#define WITH_CREAT 1
#define WITH_GOPEN 1
#define WITH_TERMIOS 1
#define WITH_PIPE 1
#define WITH_UNIX 1
#define WITH_ABSTRACT_UNIXSOCKET 1
#define WITH_IP4 1
#define WITH_IP6 1
#define WITH_RAWIP 1
#define WITH_GENERICSOCKET 1
#define WITH_INTERFACE 1
#define WITH_TCP 1
#define WITH_UDP 1
#define WITH_SCTP 1
#define WITH_LISTEN 1
#define WITH_SOCKS4 1
#define WITH_SOCKS4A 1
#define WITH_PROXY 1
#define WITH_SYSTEM 1
#define WITH_EXEC 1
#undef WITH_READLINE
#define WITH_TUN 1
#define WITH_PTY 1
#define WITH_OPENSSL 1
#undef WITH_FIPS
#define WITH_LIBWRAP 1
#define WITH_SYCLS 1
#define WITH_FILAN 1
#define WITH_RETRY 1
#define WITH_MSGLEVEL 0 /*debug*/
root@vps:~# root@vps:~# /root/.acme.sh/acme.sh --issue -d souqsquare.com -d www.souqsquare.com --cert-file /etc/letsencrypt/live/www.rmronsol.com/cert.pem --key-file /etc/letsencrypt/live/souqsquare.com/privkey.pem --fullchain-file /etc/letsencrypt/live/souqsquare.com/fullchain.pem -w /home/souqsquare.com/public_html --server letsencrypt --force --debug
-bash: root@vps:~#: command not found
root@vps:~# [Sun 29 Jan 2023 05:03:25 PM UTC] Selected server: https://acme-v02.api.letsencrypt.org/directory
-bash: [Sun: command not found
root@vps:~# [Sun 29 Jan 2023 05:03:25 PM UTC] Lets find script dir.
root@vps:~# [Sun 29 Jan 2023 05:03:25 PM UTC] _SCRIPT_='/root/.acme.sh/acme.sh'
root@vps:~# [Sun 29 Jan 2023 05:03:25 PM UTC] _script='/root/.acme.sh/acme.sh'
root@vps:~# [Sun 29 Jan 2023 05:03:25 PM UTC] _script_home='/root/.acme.sh'
root@vps:~# [Sun 29 Jan 2023 05:03:25 PM UTC] Using config home:/root/.acme.sh
root@vps:~# https://github.com/acmesh-official/acme.sh
-bash: https://github.com/acmesh-official/acme.sh: No such file or directory
root@vps:~# v3.0.5
-bash: v3.0.5: command not found
A post was merged into an existing topic: Cannot issue SSL on cyberpanel
