SSL_CTX_use_PrivateKey failed (SSL: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch)
My domain is:dsrlearn.com
I ran this command:certbot certonly --preferred-challenges=dns --manual --agree-tos --email srinivasarao10247@gmail.com --server https://acme-v02.api.letsencrypt.org/directory --work-dir=. --config-dir=. --logs-dir=. --csr dsrlearn.csr -d dsrlearn.com -d *.dsrlearn.com
It produced this output: i ran nginx -t got SSL_CTX_use_PrivateKey failed (SSL: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch)
My web server is (include version):1.21.4
The operating system my web server runs on is (include version):ubuntu 20.04
My hosting provider, if applicable, is:upcloud
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):1.23.0
It would appear that your Nginx configuration points to a Key which does NOT match the Certificate.
Could you start by posting your Nginx configuration?
This is a duplicate post from:
