SSL certificated not working
Hi All?
I have installed Let's Encrypt on Centos 8 by following https://www.digitaloc
ean.com/community/tutorials/how-to-secure-apache-with-let-s-encrypt-on-centos-8
The let's encrypt has been installed, the certificate files have been generated, and auto /etc/httpd/sites-available/thinkingfree.org-le-ssl.conf config file for ssl has been created.
There is no fatal error in httpd server logs, no fatal error in let'sencrypt logs at following path. /var/log/letsencrypt/letsencrypt.log but still SSL not working for my website. The URL is given below. https://thinkingfree.org/piwik/
The httpd server logs are below.
[Sat Jul 17 16:11:15.624493 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 16:11:15.758440 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 16:54:38.630029 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 16:59:40.844300 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 16:59:45.353276 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 16:59:47.655957 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 16:59:52.980805 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 16:59:58.432963 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 17:00:02.650882 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 17:00:04.894383 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 17:00:09.923516 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 17:00:13.429092 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 17:16:21.344325 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 18:37:21.704105 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sat Jul 17 18:49:39.298253 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
[Sun Jul 18 03:17:02.214819 2021] [ssl:warn] [pid 98326:tid 140663162267968] AH01909: www.thinkingfree.org:443:0 server certificate does NOT include an ID which matches the server name
Any help would be appreciated.
Thanks!
Welcome to the Let's Encrypt Community :slightly_smiling_face:
At present, thinkingfree.org and www.thinkingfree.org are both serving this (incorrect) certificate:
Please show the output of:
sudo apachectl -S
Here is the output of Sudo apachectl -S
irtualHost configuration:
88.99.190.130:443 www.samtuke.com (/etc/httpd/sites-available/samtuke.com-le-ssl.conf:2)
*:80 is a NameVirtualHost
default server www.samtuke.com (/etc/httpd/sites-enabled/samtuke.com.conf:1)
port 80 namevhost www.samtuke.com (/etc/httpd/sites-enabled/samtuke.com.conf:1)
alias samtuke.com
port 80 namevhost www.thinkingfree.org (/etc/httpd/sites-enabled/thinkingfree.org.conf:1)
alias thinkingfree.org
*:443 is a NameVirtualHost
default server samtuke.com (/etc/httpd/conf.d/ssl.conf:40)
port 443 namevhost samtuke.com (/etc/httpd/conf.d/ssl.conf:40)
port 443 namevhost thinkingfree.org (/etc/httpd/sites-available/thinkingfree.org-le-ssl.conf:2)
alias www.thinkingfree.org
ServerRoot: "/etc/httpd"
Main ErrorLog: "/etc/httpd/logs/error_log"
Mutex proxy-balancer-shm: using_defaults
Mutex authdigest-client: using_defaults
Mutex lua-ivm-shm: using_defaults
Mutex proxy: using_defaults
Mutex authn-socache: using_defaults
Mutex default: dir="/etc/httpd/run/" mechanism=default
Mutex cache-socache: using_defaults
Mutex authdigest-opaque: using_defaults
PidFile: "/etc/httpd/run/httpd.pid"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="apache" id=48
Group: name="apache" id=48
Can you please guide me why it is incorrect certificate and how can I generate correct certificate?
What are the outputs of:
sudo ls -lRa /etc/httpd
sudo ls -lRa /etc/letsencrypt
sudo certbot certificates
sudo cat /etc/httpd/conf.d/ssl.conf
sudo cat /etc/httpd/sites-available/samtuke.com-le-ssl.conf
sudo cat /etc/httpd/sites-available/thinkingfree.org-le-ssl.conf
sudo cat /etc/httpd/sites-enabled/samtuke.com.conf
sudo cat /etc/httpd/sites-enabled/thinkingfree.org.conf
Please put 3 backticks above and below each output, like this:
output
The output of sudo ls -lRa /etc/httpd
/etc/httpd:
total 28
drwxr-xr-x. 7 root root 4096 Jul 17 17:00 .
drwxr-xr-x. 94 root root 4096 Jul 17 15:44 ..
drwxr-xr-x. 2 root root 4096 Jul 17 16:01 conf
drwxr-xr-x. 2 root root 4096 Jul 17 17:00 conf.d
drwxr-xr-x. 2 root root 4096 Jul 11 13:44 conf.modules.d
lrwxrwxrwx. 1 root root 19 Jun 29 22:09 logs -> ../../var/log/httpd
lrwxrwxrwx. 1 root root 29 Jun 29 22:09 modules -> ../../usr/lib64/httpd/modules
lrwxrwxrwx. 1 root root 10 Jun 29 22:09 run -> /run/httpd
drwxr-xr-x. 2 root root 4096 Jul 19 05:48 sites-available
drwxr-xr-x. 2 root root 4096 Jul 17 18:49 sites-enabled
lrwxrwxrwx. 1 root root 19 Jun 29 22:09 state -> ../../var/lib/httpd
/etc/httpd/conf:
total 36
drwxr-xr-x. 2 root root 4096 Jul 17 16:01 .
drwxr-xr-x. 7 root root 4096 Jul 17 17:00 ..
-rw-r--r--. 1 root root 12127 Jul 17 16:01 httpd.conf
-rw-r--r--. 1 root root 13064 Jun 29 22:09 magic
/etc/httpd/conf.d:
total 40
drwxr-xr-x. 2 root root 4096 Jul 17 17:00 .
-rw-r--r--. 1 root root 400 Jun 29 22:11 README
-rw-r--r--. 1 root root 2926 Jun 29 22:09 autoindex.conf
-rw-r--r--. 1 root root 1618 May 7 2020 php.conf
-rw-r--r--. 1 root root 8737 Mar 17 10:47 ssl.conf
-rw-r--r--. 1 root root 1252 Jun 29 22:07 userdir.conf
-rw-r--r--. 1 root root 574 Jun 29 22:07 welcome.conf
/etc/httpd/conf.modules.d:
total 60
drwxr-xr-x. 2 root root 4096 Jul 11 13:44 .
-rw-r--r--. 1 root root 3311 Jun 29 22:07 00-base.conf
-rw-r--r--. 1 root root 139 Jun 29 22:07 00-dav.conf
-rw-r--r--. 1 root root 41 Jun 29 22:07 00-lua.conf
-rw-r--r--. 1 root root 948 Jun 29 22:07 00-mpm.conf
-rw-r--r--. 1 root root 787 Jun 29 22:07 00-optional.conf
-rw-r--r--. 1 root root 1073 Jun 29 22:07 00-proxy.conf
-rw-r--r--. 1 root root 41 Jun 29 22:07 00-ssl.conf
-rw-r--r--. 1 root root 88 Jun 29 22:07 00-systemd.conf
-rw-r--r--. 1 root root 451 Jun 29 22:07 01-cgi.conf
-rw-r--r--. 1 root root 45 May 20 06:43 10-h2.conf
-rw-r--r--. 1 root root 57 May 20 06:43 10-proxy_h2.conf
-rw-r--r--. 1 root root 299 May 7 2020 15-php.conf
-rw-r--r--. 1 root root 496 Jun 29 22:09 README
/etc/httpd/sites-available:
total 24
drwxr-xr-x. 2 root root 4096 Jul 19 05:48 .
-rw-r--r--. 1 root root 611 Mar 17 11:39 samtuke.com-le-ssl.conf
-rw-r--r--. 1 root root 550 Jun 16 15:08 samtuke.com.conf
-rw-r--r--. 1 root root 506 Jul 19 05:48 thinkingfree.org-le-ssl.conf
-rw-r--r--. 1 root root 466 Jul 18 04:42 thinkingfree.org.conf
/etc/httpd/sites-enabled:
total 8
drwxr-xr-x. 2 root root 4096 Jul 17 18:49 .
lrwxrwxrwx. 1 root root 43 Mar 14 19:09 samtuke.com.conf -> /etc/httpd/sites-available/samtuke.com.conf
lrwxrwxrwx. 1 root root 48 Mar 14 19:33 thinkingfree.org.conf -> /etc/httpd/sites-available/thinkingfree.org.conf
The output of sudo ls -lRa /etc/letsencrypt
/etc/letsencrypt:
total 44
drwxr-xr-x. 9 root root 4096 Jul 19 00:05 .
-rw-r--r--. 1 root root 64 Mar 17 10:44 .updated-options-ssl-apache-conf-digest.txt
drwx------. 4 root root 4096 Jun 16 15:08 accounts
drwx------. 5 root root 4096 Jul 17 16:11 archive
drwxr-xr-x. 2 root root 4096 Jul 17 16:11 csr
drwx------. 2 root root 4096 Jul 17 16:11 keys
drwx------. 5 root root 4096 Jul 17 16:11 live
-rw-r--r--. 1 root root 952 Mar 17 11:34 options-ssl-apache.conf
drwxr-xr-x. 2 root root 4096 Jul 17 16:11 renewal
drwxr-xr-x. 5 root root 4096 Mar 17 10:30 renewal-hooks
/etc/letsencrypt/accounts:
total 16
drwx------. 4 root root 4096 Jun 16 15:08 .
drwxr-xr-x. 9 root root 4096 Jul 19 00:05 ..
drwx------. 3 root root 4096 Jun 16 15:08 acme-staging-v02.api.letsencrypt.org
drwx------. 3 root root 4096 Mar 17 10:32 acme-v02.api.letsencrypt.org
/etc/letsencrypt/accounts/acme-staging-v02.api.letsencrypt.org:
total 12
drwx------. 3 root root 4096 Jun 16 15:08 .
drwx------. 4 root root 4096 Jun 16 15:08 ..
drwx------. 3 root root 4096 Jun 16 15:08 directory
/etc/letsencrypt/accounts/acme-staging-v02.api.letsencrypt.org/directory:
total 12
drwx------. 3 root root 4096 Jun 16 15:08 ..
drwx------. 2 root root 4096 Jun 16 15:08 522156640293e7d37dfa75bd71a806a3
/etc/letsencrypt/accounts/acme-staging-v02.api.letsencrypt.org/directory/522156640293e7d37dfa75bd71a806a3:
total 20
drwx------. 2 root root 4096 Jun 16 15:08 .
-rw-r--r--. 1 root root 71 Jun 16 15:08 meta.json
-r--------. 1 root root 1632 Jun 16 15:08 private_key.json
-rw-r--r--. 1 root root 86 Jun 16 15:08 regr.json
/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org:
total 12
drwx------. 3 root root 4096 Mar 17 10:32 .
drwx------. 3 root root 4096 Mar 17 10:33 directory
/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory:
total 12
drwx------. 3 root root 4096 Mar 17 10:33 .
drwx------. 3 root root 4096 Mar 17 10:32 ..
drwx------. 2 root root 4096 Mar 17 10:33 b372c11eb66949aa0a46f6292f6023fb
/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory/b372c11eb66949aa0a46f6292f6023fb:
total 20
drwx------. 2 root root 4096 Mar 17 10:33 .
drwx------. 3 root root 4096 Mar 17 10:33 ..
-rw-r--r--. 1 root root 71 Mar 17 10:33 meta.json
-r--------. 1 root root 1632 Mar 17 10:33 private_key.json
-rw-r--r--. 1 root root 79 Mar 17 10:33 regr.json
/etc/letsencrypt/archive:
total 20
drwx------. 5 root root 4096 Jul 17 16:11 .
drwxr-xr-x. 2 root root 4096 Jul 17 16:01 thinkingfree.org
drwxr-xr-x. 2 root root 4096 Jul 17 16:11 thinkingfree.org-0001
drwxr-xr-x. 2 root root 4096 Jun 16 15:13 www.samtuke.com
/etc/letsencrypt/archive/thinkingfree.org:
total 28
drwx------. 5 root root 4096 Jul 17 16:11 ..
-rw-r--r--. 1 root root 1879 Jul 17 16:01 cert1.pem
-rw-r--r--. 1 root root 3749 Jul 17 16:01 chain1.pem
-rw-r--r--. 1 root root 5628 Jul 17 16:01 fullchain1.pem
-rw-------. 1 root root 1704 Jul 17 16:01 privkey1.pem
/etc/letsencrypt/archive/thinkingfree.org-0001:
total 28
drwxr-xr-x. 2 root root 4096 Jul 17 16:11 .
-rw-r--r--. 1 root root 1846 Jul 17 16:11 cert1.pem
-rw-r--r--. 1 root root 3749 Jul 17 16:11 chain1.pem
-rw-r--r--. 1 root root 5595 Jul 17 16:11 fullchain1.pem
-rw-------. 1 root root 1704 Jul 17 16:11 privkey1.pem
/etc/letsencrypt/archive/www.samtuke.com:
total 44
drwxr-xr-x. 2 root root 4096 Jun 16 15:13 .
-rw-r--r--. 1 root root 1862 Mar 17 10:48 cert1.pem
-rw-r--r--. 1 root root 1862 Jun 16 15:13 cert2.pem
-rw-r--r--. 1 root root 1586 Mar 17 10:48 chain1.pem
-rw-r--r--. 1 root root 3749 Jun 16 15:13 chain2.pem
-rw-r--r--. 1 root root 3448 Mar 17 10:48 fullchain1.pem
-rw-r--r--. 1 root root 5611 Jun 16 15:13 fullchain2.pem
-rw-------. 1 root root 1704 Mar 17 10:48 privkey1.pem
-rw-------. 1 root root 1704 Jun 16 15:13 privkey2.pem
/etc/letsencrypt/csr:
total 48
-rw-r--r--. 1 root root 944 Mar 17 10:34 0000_csr-certbot.pem
-rw-r--r--. 1 root root 944 Mar 17 10:44 0001_csr-certbot.pem
-rw-r--r--. 1 root root 944 Mar 17 10:45 0002_csr-certbot.pem
-rw-r--r--. 1 root root 944 Mar 17 10:48 0003_csr-certbot.pem
-rw-r--r--. 1 root root 944 Jun 14 12:25 0004_csr-certbot.pem
-rw-r--r--. 1 root root 944 Jun 14 18:06 0005_csr-certbot.pem
-rw-r--r--. 1 root root 944 Jun 16 14:26 0006_csr-certbot.pem
-rw-r--r--. 1 root root 944 Jun 16 15:13 0007_csr-certbot.pem
-rw-r--r--. 1 root root 956 Jul 17 16:01 0008_csr-certbot.pem
-rw-r--r--. 1 root root 928 Jul 17 16:11 0009_csr-certbot.pem
/etc/letsencrypt/keys:
total 48
drwx------. 2 root root 4096 Jul 17 16:11 .
-rw-------. 1 root root 1708 Mar 17 10:34 0000_key-certbot.pem
-rw-------. 1 root root 1704 Mar 17 10:44 0001_key-certbot.pem
-rw-------. 1 root root 1704 Mar 17 10:45 0002_key-certbot.pem
-rw-------. 1 root root 1704 Mar 17 10:48 0003_key-certbot.pem
-rw-------. 1 root root 1704 Jun 14 12:25 0004_key-certbot.pem
-rw-------. 1 root root 1704 Jun 14 18:06 0005_key-certbot.pem
-rw-------. 1 root root 1704 Jun 16 14:26 0006_key-certbot.pem
-rw-------. 1 root root 1704 Jun 16 15:13 0007_key-certbot.pem
-rw-------. 1 root root 1704 Jul 17 16:01 0008_key-certbot.pem
-rw-------. 1 root root 1704 Jul 17 16:11 0009_key-certbot.pem
/etc/letsencrypt/live:
total 24
-rw-r--r--. 1 root root 740 Mar 17 10:48 README
/etc/letsencrypt/live/thinkingfree.org:
total 12
-rw-r--r--. 1 root root 692 Jul 17 16:01 README
lrwxrwxrwx. 1 root root 40 Jul 17 16:01 cert.pem -> ../../archive/thinkingfree.org/cert1.pem
lrwxrwxrwx. 1 root root 41 Jul 17 16:01 chain.pem -> ../../archive/thinkingfree.org/chain1.pem
lrwxrwxrwx. 1 root root 45 Jul 17 16:01 fullchain.pem -> ../../archive/thinkingfree.org/fullchain1.pem
lrwxrwxrwx. 1 root root 43 Jul 17 16:01 privkey.pem -> ../../archive/thinkingfree.org/privkey1.pem
/etc/letsencrypt/live/thinkingfree.org-0001:
total 12
-rw-r--r--. 1 root root 692 Jul 17 16:11 README
lrwxrwxrwx. 1 root root 45 Jul 17 16:11 cert.pem -> ../../archive/thinkingfree.org-0001/cert1.pem
lrwxrwxrwx. 1 root root 46 Jul 17 16:11 chain.pem -> ../../archive/thinkingfree.org-0001/chain1.pem
lrwxrwxrwx. 1 root root 50 Jul 17 16:11 fullchain.pem -> ../../archive/thinkingfree.org-0001/fullchain1.pem
lrwxrwxrwx. 1 root root 48 Jul 17 16:11 privkey.pem -> ../../archive/thinkingfree.org-0001/privkey1.pem
/etc/letsencrypt/live/www.samtuke.com:
total 12
-rw-r--r--. 1 root root 692 Mar 17 10:48 README
lrwxrwxrwx. 1 root root 39 Jun 16 15:13 cert.pem -> ../../archive/www.samtuke.com/cert2.pem
lrwxrwxrwx. 1 root root 40 Jun 16 15:13 chain.pem -> ../../archive/www.samtuke.com/chain2.pem
lrwxrwxrwx. 1 root root 44 Jun 16 15:13 fullchain.pem -> ../../archive/www.samtuke.com/fullchain2.pem
lrwxrwxrwx. 1 root root 42 Jun 16 15:13 privkey.pem -> ../../archive/www.samtuke.com/privkey2.pem
/etc/letsencrypt/renewal:
total 20
-rw-r--r--. 1 root root 564 Jul 17 16:11 thinkingfree.org-0001.conf
-rw-r--r--. 1 root root 539 Jul 17 16:01 thinkingfree.org.conf
-rw-r--r--. 1 root root 534 Jun 16 15:13 www.samtuke.com.conf
/etc/letsencrypt/renewal-hooks:
total 20
drwxr-xr-x. 5 root root 4096 Mar 17 10:30 .
drwxr-xr-x. 2 root root 4096 Mar 17 10:30 deploy
drwxr-xr-x. 2 root root 4096 Mar 17 10:30 post
drwxr-xr-x. 2 root root 4096 Mar 17 10:30 pre
/etc/letsencrypt/renewal-hooks/deploy:
total 8
drwxr-xr-x. 2 root root 4096 Mar 17 10:30 .
drwxr-xr-x. 5 root root 4096 Mar 17 10:30 ..
/etc/letsencrypt/renewal-hooks/post:
total 8
/etc/letsencrypt/renewal-hooks/pre:
total 8
Looking good so far. Some small things to cleanup.
/etc/letsencrypt:
total 44
total 16
total 12
total 12
total 20
total 12
total 12
total 20
total 20
total 28
total 28
total 44
total 48
total 48
total 24
total 12
total 12
total 12
total 20
total 20
total 8
total 8
total 8
[hafiznaseraslam@samtuke ~]$ sudo certbot certificates
Found the following certs:
  Certificate Name: thinkingfree.org-0001
    Serial Number: 3ebd665cb36313d31031eb436163a56609e
    Key Type: RSA
    Domains: thinkingfree.org
    Expiry Date: 2021-10-15 13:11:11+00:00 (VALID: 88 days)
    Certificate Path: /etc/letsencrypt/live/thinkingfree.org-0001/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/thinkingfree.org-0001/privkey.pem
    Serial Number: 314de565ba406eb8c7eac2779d2170619eb
    Key Type: RSA
    Domains: thinkingfree.org www.thinkingfree.org
    Expiry Date: 2021-10-15 13:01:36+00:00 (VALID: 88 days)
    Certificate Path: /etc/letsencrypt/live/thinkingfree.org/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/thinkingfree.org/privkey.pem
  Certificate Name: www.samtuke.com
    Serial Number: 478a17742b005568b67e86a002ac76cd830
    Key Type: RSA
    Domains: www.samtuke.com samtuke.com
    Expiry Date: 2021-09-14 12:13:29+00:00 (VALID: 57 days)
    Certificate Path: /etc/letsencrypt/live/www.samtuke.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/www.samtuke.com/privkey.pem
# When we also provide SSL we have to listen to the
# standard HTTPS port in addition.
Listen 443 https
##  SSL Global Context
##  All SSL configuration in this context applies both to
##  the main server and all SSL-enabled virtual hosts.
#   Pass Phrase Dialog:
#   Configure the pass phrase gathering process.
#   The filtering dialog program (`builtin' is a internal
#   terminal dialog) has to provide the pass phrase on stdout.
SSLPassPhraseDialog exec:/usr/libexec/httpd-ssl-pass-dialog
#   Inter-Process Session Cache:
#   Configure the SSL Session Cache: First the mechanism
#   to use and second the expiring timeout (in seconds).
SSLSessionCache         shmcb:/run/httpd/sslcache(512000)
SSLSessionCacheTimeout  300
# Use "SSLCryptoDevice" to enable any supported hardware
# accelerators. Use "openssl engine -v" to list supported
# engine names.  NOTE: If you enable an accelerator and the
# server does not start, consult the error logs and ensure
# your accelerator is functioning properly.
SSLCryptoDevice builtin
#SSLCryptoDevice ubsec
## SSL Virtual Host Context
<VirtualHost _default_:443>
# General setup for the virtual host, inherited from global configuration
#DocumentRoot "/var/www/html"
#ServerName www.example.com:443
# Use separate log files for the SSL virtual host; note that LogLevel
# is not inherited from httpd.conf.
ErrorLog logs/ssl_error_log
TransferLog logs/ssl_access_log
LogLevel warn
#   SSL Engine Switch:
#   Enable/Disable SSL for this virtual host.
#SSLEngine on
SSLEngine off
#   List the protocol versions which clients are allowed to connect with.
#   The OpenSSL system profile is used by default.  See
#   update-crypto-policies(8) for more details.
#SSLProtocol all -SSLv3
#SSLProxyProtocol all -SSLv3
#   User agents such as web browsers are not configured for the user's
#   own preference of either security or performance, therefore this
#   must be the prerogative of the web server administrator who manages
#   cpu load versus confidentiality, so enforce the server's cipher order.
SSLHonorCipherOrder on
#   SSL Cipher Suite:
#   List the ciphers that the client is permitted to negotiate.
#   See the mod_ssl documentation for a complete list.
#   The OpenSSL system profile is configured by default.  See
SSLCipherSuite PROFILE=SYSTEM
SSLProxyCipherSuite PROFILE=SYSTEM
#   Point SSLCertificateFile at a PEM encoded certificate.  If
#   the certificate is encrypted, then you will be prompted for a
#   pass phrase.  Note that restarting httpd will prompt again.  Keep
#   in mind that if you have both an RSA and a DSA certificate you
#   can configure both in parallel (to also allow the use of DSA
#   ciphers, etc.)
#   Some ECC cipher suites (http://www.ietf.org/rfc/rfc4492.txt)
#   require an ECC certificate which can also be configured in
#   parallel.
#SSLCertificateFile /etc/pki/tls/certs/localhost.crt
#   Server Private Key:
#   If the key is not combined with the certificate, use this
#   directive to point at the key file.  Keep in mind that if
#   you've both a RSA and a DSA private key you can configure
#   both in parallel (to also allow the use of DSA ciphers, etc.)
#   ECC keys, when in use, can also be configured in parallel
#SSLCertificateKeyFile /etc/pki/tls/private/localhost.key
#   Server Certificate Chain:
#   Point SSLCertificateChainFile at a file containing the
#   concatenation of PEM encoded CA certificates which form the
#   certificate chain for the server certificate. Alternatively
#   the referenced file can be the same as SSLCertificateFile
#   when the CA certificates are directly appended to the server
#   certificate for convenience.
#SSLCertificateChainFile /etc/pki/tls/certs/server-chain.crt
#   Certificate Authority (CA):
#   Set the CA certificate verification path where to find CA
#   certificates for client authentication or alternatively one
#   huge file containing all of them (file must be PEM encoded)
#SSLCACertificateFile /etc/pki/tls/certs/ca-bundle.crt
#   Client Authentication (Type):
#   Client certificate verification type and depth.  Types are
#   none, optional, require and optional_no_ca.  Depth is a
#   number which specifies how deeply to verify the certificate
#   issuer chain before deciding the certificate is not valid.
#SSLVerifyClient require
#SSLVerifyDepth  10
#   Access Control:
#   With SSLRequire you can do per-directory access control based
#   on arbitrary complex boolean expressions containing server
#   variable checks and other lookup directives.  The syntax is a
#   mixture between C and Perl.  See the mod_ssl documentation
#   for more details.
#<Location />
#SSLRequire (    %{SSL_CIPHER} !~ m/^(EXP|NULL)/ \
#            and %{SSL_CLIENT_S_DN_O} eq "Snake Oil, Ltd." \
#            and %{SSL_CLIENT_S_DN_OU} in {"Staff", "CA", "Dev"} \
#            and %{TIME_WDAY} >= 1 and %{TIME_WDAY} <= 5 \
#            and %{TIME_HOUR} >= 8 and %{TIME_HOUR} <= 20       ) \
#           or %{REMOTE_ADDR} =~ m/^192\.76\.162\.[0-9]+$/
#</Location>
#   SSL Engine Options:
#   Set various options for the SSL engine.
#   o FakeBasicAuth:
#     Translate the client X.509 into a Basic Authorisation.  This means that
#     the standard Auth/DBMAuth methods can be used for access control.  The
#     user name is the `one line' version of the client's X.509 certificate.
#     Note that no password is obtained from the user. Every entry in the user
#     file needs this password: `xxj31ZMTZzkVA'.
#   o ExportCertData:
#     This exports two additional environment variables: SSL_CLIENT_CERT and
#     SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
#     server (always existing) and the client (only existing when client
#     authentication is used). This can be used to import the certificates
#     into CGI scripts.
#   o StdEnvVars:
#     This exports the standard SSL/TLS related `SSL_*' environment variables.
#     Per default this exportation is switched off for performance reasons,
#     because the extraction step is an expensive operation and is usually
#     useless for serving static content. So one usually enables the
#     exportation for CGI and SSI requests only.
#   o StrictRequire:
#     This denies access when "SSLRequireSSL" or "SSLRequire" applied even
#     under a "Satisfy any" situation, i.e. when it applies access is denied
#     and no other module can change it.
#   o OptRenegotiate:
#     This enables optimized SSL connection renegotiation handling when SSL
#     directives are used in per-directory context.
#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
<FilesMatch "\.(cgi|shtml|phtml|php)$">
    SSLOptions +StdEnvVars
</FilesMatch>
<Directory "/var/www/cgi-bin">
</Directory>
#   SSL Protocol Adjustments:
#   The safe and default but still SSL/TLS standard compliant shutdown
#   approach is that mod_ssl sends the close notify alert but doesn't wait for
#   the close notify alert from client. When you need a different shutdown
#   approach you can use one of the following variables:
#   o ssl-unclean-shutdown:
#     This forces an unclean shutdown when the connection is closed, i.e. no
#     SSL close notify alert is sent or allowed to be received.  This violates
#     the SSL/TLS standard but is needed for some brain-dead browsers. Use
#     this when you receive I/O errors because of the standard approach where
#     mod_ssl sends the close notify alert.
#   o ssl-accurate-shutdown:
#     This forces an accurate shutdown when the connection is closed, i.e. a
#     SSL close notify alert is sent and mod_ssl waits for the close notify
#     alert of the client. This is 100% SSL/TLS standard compliant, but in
#     practice often causes hanging connections with brain-dead browsers. Use
#     this only for browsers where you know that their SSL implementation
#     works correctly.
#   Notice: Most problems of broken clients are also related to the HTTP
#   keep-alive facility, so you usually additionally want to disable
#   keep-alive for those clients, too. Use variable "nokeepalive" for this.
#   Similarly, one has to force some clients to use HTTP/1.0 to workaround
#   their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
#   "force-response-1.0" for this.
BrowserMatch "MSIE [2-5]" \
         nokeepalive ssl-unclean-shutdown \
         downgrade-1.0 force-response-1.0
#   Per-Server Logging:
#   The home of a custom SSL log file. Use this when you want a
#   compact non-error SSL logfile on a virtual host basis.
CustomLog logs/ssl_request_log \
          "%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x \"%r\" %b"
</VirtualHost>
<IfModule mod_ssl.c>
<VirtualHost 88.99.190.130:443>
    ServerName www.samtuke.com
    ServerAlias samtuke.com
    DocumentRoot /var/www/samtuke.com/public_html
<Directory "/var/www/samtuke.com">
	AllowOverride all
	Require all granted
</Directory>
    ErrorLog /var/www/samtuke.com/log/error.log
    CustomLog /var/www/samtuke.com/log/requests.log combined
SSLCertificateFile /etc/letsencrypt/live/www.samtuke.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/www.samtuke.com/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:443>
    ServerName thinkingfree.org
    ServerAlias www.thinkingfree.org
    DocumentRoot /var/www/thinkingfree.org/public_html
    ErrorLog /var/www/thinkingfree.org/log/error.log
    CustomLog /var/www/thinkingfree.org/log/requests.log combined
SSLCertificateFile /etc/letsencrypt/live/thinkingfree.org/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/thinkingfree.org/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:80>
	AllowOverride all
	Require all granted
</Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =samtuke.com [OR]
RewriteCond %{SERVER_NAME} =www.samtuke.com
</VirtualHost>
<VirtualHost *:80>
    ServerName www.thinkingfree.org
    ServerAlias thinkingfree.org
RewriteEngine on
RewriteCond %{SERVER_NAME} =thinkingfree.org [OR]
RewriteCond %{SERVER_NAME} =www.thinkingfree.org
</VirtualHost>
Can you please guide me or ask me if you want me to share any other log file?
I'm digesting things now. This might take a bit...
No problem. Please take your time and thanks a lot in advance!
What is the output of:
sudo cat /etc/httpd/conf/httpd.conf
[hafiznaseraslam@samtuke ~]$ sudo cat /etc/httpd/conf/httpd.conf
[sudo] password for hafiznaseraslam:
# This is the main Apache HTTP server configuration file.  It contains the
# configuration directives that give the server its instructions.
# See <URL:http://httpd.apache.org/docs/2.4/> for detailed information.
# In particular, see
# <URL:http://httpd.apache.org/docs/2.4/mod/directives.html>
# for a discussion of each configuration directive.
# See the httpd.conf(5) man page for more information on this configuration,
# and httpd.service(8) on using and configuring the httpd service.
# Do NOT simply read the instructions in here without understanding
# what they do.  They're here only as hints or reminders.  If you are unsure
# consult the online docs. You have been warned.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path.  If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so 'log/access_log'
# with ServerRoot set to '/www' will be interpreted by the
# server as '/www/log/access_log', where as '/log/access_log' will be
# interpreted as '/log/access_log'.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# Do not add a slash at the end of the directory path.  If you point
# ServerRoot at a non-local disk, be sure to specify a local disk on the
# Mutex directive, if file-based mutexes are used.  If you wish to share the
# same ServerRoot for multiple httpd daemons, you will need to change at
# least PidFile.
ServerRoot "/etc/httpd"
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, instead of the default. See also the <VirtualHost>
# directive.
# Change this to Listen on specific IP addresses as shown below to
# prevent Apache from glomming onto all bound IP addresses.
#Listen 12.34.56.78:80
Listen 80
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Statically compiled modules (those listed by `httpd -l') do not need
# to be loaded here.
# Example:
# LoadModule foo_module modules/mod_foo.so
Include conf.modules.d/*.conf
# If you wish httpd to run as a different user or group, you must run
# httpd as root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run httpd as.
# It is usually good practice to create a dedicated user and group for
# running httpd, as with most system services.
User apache
Group apache
# 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition.  These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# ServerAdmin: Your address, where problems with the server should be
# e-mailed.  This address appears on some server-generated pages, such
# as error documents.  e.g. admin@your-domain.com
ServerAdmin root@localhost
# ServerName gives the name and port that the server uses to identify itself.
# This can often be determined automatically, but we recommend you specify
# it explicitly to prevent problems during startup.
# If your host doesn't have a registered DNS name, enter its IP address here.
#ServerName www.example.com:80
# Deny access to the entirety of your server's filesystem. You must
# explicitly permit access to web content directories in other
# <Directory> blocks below.
<Directory />
    AllowOverride none
    Require all denied
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
# Relax access to content within /var/www.
<Directory "/var/www">
    AllowOverride All
    # Allow open access:
    Require all granted
</Directory>
# Further relax access to the default document root:
<Directory "/var/www/html">
    # Possible values for the Options directive are "None", "All",
    # or any combination of:
    #   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
    # Note that "MultiViews" must be named *explicitly* --- "Options All"
    # doesn't give it to you.
    # The Options directive is both complicated and important.  Please see
    # http://httpd.apache.org/docs/2.4/mod/core.html#options
    # for more information.
    # AllowOverride controls what directives may be placed in .htaccess files.
    # It can be "All", "None", or any combination of the keywords:
    #   Options FileInfo AuthConfig Limit
    AllowOverride None
    # Controls who can get stuff from this server.
    Require all granted
</Directory>
# DirectoryIndex: sets the file that Apache will serve if a directory
# is requested.
<IfModule dir_module>
    DirectoryIndex index.html
</IfModule>
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ".ht*">
    Require all denied
</Files>
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here.  If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog "logs/error_log"
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
<IfModule log_config_module>
    # The following directives define some format nicknames for use with
    # a CustomLog directive (see below).
    LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
    LogFormat "%h %l %u %t \"%r\" %>s %b" common
    <IfModule logio_module>
      # You need to enable mod_logio.c to use %I and %O
      LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
    </IfModule>
    # The location and format of the access logfile (Common Logfile Format).
    # If you do not define any access logfiles within a <VirtualHost>
    # container, they will be logged here.  Contrariwise, if you *do*
    # define per-<VirtualHost> access logfiles, transactions will be
    # logged therein and *not* in this file.
    #CustomLog "logs/access_log" common
    # If you prefer a logfile with access, agent, and referer information
    # (Combined Logfile Format) you can use the following directive.
    CustomLog "logs/access_log" combined
</IfModule>
<IfModule alias_module>
    # Redirect: Allows you to tell clients about documents that used to
    # exist in your server's namespace, but do not anymore. The client
    # will make a new request for the document at its new location.
    # Example:
    # Redirect permanent /foo http://www.example.com/bar
    # Alias: Maps web paths into filesystem paths and is used to
    # access content that does not live under the DocumentRoot.
    # Example:
    # Alias /webpath /full/filesystem/path
    # If you include a trailing / on /webpath then the server will
    # require it to be present in the URL.  You will also likely
    # need to provide a <Directory> section to allow access to
    # the filesystem path.
    # ScriptAlias: This controls which directories contain server scripts.
    # ScriptAliases are essentially the same as Aliases, except that
    # documents in the target directory are treated as applications and
    # run by the server when requested rather than as documents sent to the
    # client.  The same rules about trailing "/" apply to ScriptAlias
    # directives as to Alias.
    ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
</IfModule>
# "/var/www/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
    AllowOverride None
    Options None
    Require all granted
</Directory>
<IfModule mime_module>
    # TypesConfig points to the file containing the list of mappings from
    # filename extension to MIME-type.
    TypesConfig /etc/mime.types
    # AddType allows you to add to or override the MIME configuration
    # file specified in TypesConfig for specific file types.
    #AddType application/x-gzip .tgz
    # AddEncoding allows you to have certain browsers uncompress
    # information on the fly. Note: Not all browsers support this.
    #AddEncoding x-compress .Z
    #AddEncoding x-gzip .gz .tgz
    # If the AddEncoding directives above are commented-out, then you
    # probably should define those extensions to indicate media types:
    AddType application/x-compress .Z
    AddType application/x-gzip .gz .tgz
    # AddHandler allows you to map certain file extensions to "handlers":
    # actions unrelated to filetype. These can be either built into the server
    # or added with the Action directive (see below)
    # To use CGI scripts outside of ScriptAliased directories:
    # (You will also need to add "ExecCGI" to the "Options" directive.)
    #AddHandler cgi-script .cgi
    # For type maps (negotiated resources):
    #AddHandler type-map var
    # Filters allow you to process content before it is sent to the client.
    # To parse .shtml files for server-side includes (SSI):
    # (You will also need to add "Includes" to the "Options" directive.)
    AddType text/html .shtml
    AddOutputFilter INCLUDES .shtml
</IfModule>
# Specify a default charset for all content served; this enables
# interpretation of all content as UTF-8 by default.  To use the
# default browser choice (ISO-8859-1), or to allow the META tags
# in HTML content to override this choice, comment out this
# directive:
AddDefaultCharset UTF-8
<IfModule mime_magic_module>
    # The mod_mime_magic module allows the server to use various hints from the
    # contents of the file itself to determine its type.  The MIMEMagicFile
    # directive tells the module where the hint definitions are located.
    MIMEMagicFile conf/magic
</IfModule>
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# EnableMMAP and EnableSendfile: On systems that support it,
# memory-mapping or the sendfile syscall may be used to deliver
# files.  This usually improves server performance, but must
# be turned off when serving from networked-mounted
# filesystems or if support for these functions is otherwise
# broken on your system.
# Defaults if commented: EnableMMAP On, EnableSendfile Off
#EnableMMAP off
EnableSendfile on
# Supplemental configuration
# Load config files in the "/etc/httpd/conf.d" directory, if any.
IncludeOptional conf.d/*.conf
IncludeOptional sites-enabled/*.conf
Include /etc/httpd/sites-available/samtuke.com-le-ssl.conf
# Stop timeout of wp duplicator plugin
Timeout 600
ProxyTimeout 600
Include /etc/httpd/sites-available/thinkingfree.org-le-ssl.conf
It is strange how some files use /sites-enabled/ and some use /sites-available/.
How can I change the configuration to read all the files only from one directory?
Look for include statements within the main config file.
Place all your site configs in the /sites-available/ folder.
Enable and disable those configs using only the apache commands:
a2enconf
a2disconf
  1. Remove the cruft.
a. Remove these two lines from httpd.conf:
b. Run these commands:
sudo rm /etc/httpd/sites-enabled/*
sudo rm /etc/httpd/sites-available/*
sudo certbot delete --cert-name www.samtuke.com
sudo certbot delete --cert-name thinkingfree.org
sudo certbot delete --cert-name thinkingfree.org-0001
  1. Install your clean configuration files.
a. Download these files:
samtuke.com.conf.txt (254 Bytes)
thinkingfree.org.conf.txt (279 Bytes)
b. Put them in /etc/httpd/sites-available
c. Run these commands:
sudo mv /etc/httpd/sites-available/samtuke.com.conf.txt /etc/httpd/sites-available/samtuke.com.conf
sudo mv /etc/httpd/sites-available/thinkingfree.org.conf.txt /etc/httpd/sites-available/thinkingfree.org.conf
sudo a2ensite samtuke.com.conf
sudo a2ensite thinkingfree.org.conf
  1. Reload Apache.
sudo apachectl -k graceful
  1. Acquire and install the correct certificates.
sudo certbot --apache -d "samtuke.com,www.samtuke.com"
sudo certbot --apache -d "thinkingfree.org,www.thinkingfree.org"
