I have a NGINX server that redirects users from a subdomain (help.hellobonafide.com ) to a Shopify site (hellobonafide.com ). I am trying to renew the SSL cert with certbot but I do not understand the error message.
sudo certbot renew --dry-run
Domain: help.hellobonafide.com
Detail: 40.70.27.24: Invalid response from
https://hellobonafide.com/pages/help-center: "<!DOCTYPE
html>\n<html class=\"no-js\" lang=\"en\">\n <head><meta
charset=\"utf-8\">\n <meta http-equiv=\"X-UA-Compatible\"
content=\"IE"
nginx version: 1.14.0
Ubuntu
Yes
I'm using a control panel to manage my site:
No, just terminal
The version of my client is:
certbot 0.31.0
Hello @bansavage , welcome to the Let's Encrypt community.
This redirect seems fine.
$ curl -Ii http://help.hellobonafide.com/.well-known/acme-challenge/sometestfile
Server: nginx/1.14.0 (Ubuntu)
Date: Thu, 06 Jul 2023 22:03:11 GMT
Content-Type: text/html
Content-Length: 194
Location: https://help.hellobonafide.com/.well-known/acme-challenge/sometestfile
This redirect seems not so good.
$ curl -k -Ii https://help.hellobonafide.com/.well-known/acme-challenge/sometestfile
Date: Thu, 06 Jul 2023 22:03:13 GMT
Content-Length: 194
Location: https://www.hellobonafide.com/pages/help-center
Here is a online tool to help check your redirects https://www.redirect-checker.org/
Here is a list of issued certificates crt.sh | help.hellobonafide.com , the latest being 2023-03-31 .
What has changed since 2023-03-31?
Also this is what I see for DNS: https://dnsspy.io/scan/hellobonafide.com
Looks like help.hellobonafide.com
, www.hellobonafide.com
, and hellobonafide.com
are different machines.
Observer the redirect from help.hellobonafide.com
ultimately ends up at hellobonafide.com
Thanks for the help Bruce.
The SSL is not valid for "help.hellobonafide.com "
Here I ran command: "sudo certbot certificates"
OCSP check failed for /etc/letsencrypt/live/help.hellobonafide.com/cert.pem (are we offline?)
OCSP check failed for /etc/letsencrypt/live/patient.hellobonafide.com/cert.pem (are we offline?)
Found the following certs:
Certificate Name: api.hellobonafide.com
Domains: api.hellobonafide.com
Expiry Date: 2023-09-29 07:53:19+00:00 (VALID: 84 days)
Certificate Path: /etc/letsencrypt/live/api.hellobonafide.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/api.hellobonafide.com/privkey.pem
Certificate Name: help.hellobonafide.com
Domains: help.hellobonafide.com
Expiry Date: 2023-06-29 03:38:10+00:00 (INVALID: EXPIRED)
Certificate Path: /etc/letsencrypt/live/help.hellobonafide.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/help.hellobonafide.com/privkey.pem
Certificate Name: patient.hellobonafide.com
Domains: patient.hellobonafide.com
Expiry Date: 2023-05-30 23:52:00+00:00 (INVALID: EXPIRED)
Certificate Path: /etc/letsencrypt/live/patient.hellobonafide.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/patient.hellobonafide.com/privkey.pem
It shows my SSH certs as EXPIRED. This is contrary to the link you posted (crt.sh | help.hellobonafide.com )
Then why the redirect to it?
We are redirecting "help.hellobonafide.com " to "hellobonafide.com ".
When users first visit "help.hellobonafide.com " they hit the typically unsafe browser page (due to expired SSL)
Not from what I see for http://help.hellobonafide.com/.well-known/acme-challenge/sometestfile
Date: Thu, 06 Jul 2023 23:15:29 GMT
Content-Length: 194
Observe Location: https://help.hellobonafide.com/.well-known/acme-challenge/sometestfile
Thanks, but I don't understand. If you just go to "http://help.hellobonafide.com " on a fresh browser, you will hit the unsecure connection browser page.
Please use https://www.redirect-checker.org/ with the URL you have in quotas to see what I mean.
I see this
Result
CONGRATULATION. Everything seems to be fine.
301 Moved Permanently
200 OK
This site does not reflect the true experience though. See my screenshot above
Kindly wait to see if there are more knowledgeable Let's Encrypt community volunteers willing to assist.
crt.sh | 9048400940 shows what looks to me like EXPIRED.
Validity (Expired)
Not Before: Mar 31 03:38:11 2023 GMT
Not After : Jun 29 03:38:10 2023 GMT
Agreed, for the User Experience. But I believe this issue is not the User Experience but the Renewal of the Certificate(s ). The 2 are not necessarily the same.
@bansavage
Would you show contents of this file
/etc/letsencrypt/renewal/help.hellobonafide.com.conf
And, can you show the contents of the server block for that domain which listens on port 80? (the HTTP server block)
We'll try to fix why you can't renew your cert. The rest will resolve once that is done
We'll just do this one domain and check the other one after this is working.
Thanks for you help Mike!
Here is the contents of file : /etc/letsencrypt/renewal/help.hellobonafide.com.conf
version = 0.31.0
archive_dir = /etc/letsencrypt/archive/help.hellobonafide.com
cert = /etc/letsencrypt/live/help.hellobonafide.com/cert.pem
privkey = /etc/letsencrypt/live/help.hellobonafide.com/privkey.pem
chain = /etc/letsencrypt/live/help.hellobonafide.com/chain.pem
fullchain = /etc/letsencrypt/live/help.hellobonafide.com/fullchain.pem
[renewalparams]
account = fe0d64ea008ab1eadc073e755b520f9d
authenticator = nginx
installer = nginx
Here is the server block:
listen 443 ssl;
server_name help.hellobonafide.com;
ssl_certificate /etc/letsencrypt/live/help.hellobonafide.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/help.hellobonafide.com/privkey.pem; # managed by Certbot
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers HIGH:!aNULL:!MD5;
location ~ ^/(hc/en-us/articles/360037951753-What-is-Bonafide-) {
return 301 $scheme://hellobonafide.com/pages/help-center?a=What-is-Bonafide---id--JEiQRnDaSeGGCQBqlVn3_w;
location ~ ^/(hc/en-us/articles/360050101394-I-have-a-Bonafide-subscription-How-can-I-add-an-additional-Bonafide-product-to-my-existing-subscription-) {
return 301 $scheme://hellobonafide.com/pages/help-center?a=I-have-a-Bonafide-subscription.-How-can-I-add-an-additional-Bonafide-product-to-my-existing-subsc$
location ~ ^/(hc/en-us/articles/360050626093-I-have-multiple-Bonafide-subscriptions-How-can-I-make-changes-to-one-and-not-the-other-) {
return 301 $scheme://hellobonafide.com/pages/help-center?a=I-have-multiple-Bonafide-subscriptions.-How-can-I-make-changes-to-one-and-not-the-other---id--KVX$
if ($host = help.hellobonafide.com) {
} # managed by Certbot
listen 80;
Thanks. That's puzzling.
The --nginx plug-in authenticator inserts temp code into your http server block to handle the ACME Challenge. But, the error in your first post showed that HTTP request being redirected to HTTPS. That shouldn't happen with the --nginx authenticator. So, we need to find out why this broke.
Your system had been working reliably for some time. So, your older certbot version isn't the obvious reason for this new failure.
One obscure problem can occur with the --nginx plug-in is that nginx itself can get in a bad state. If it's easy try rebooting your server and trying the renew making sure nginx was started successfully before the renew command. If it's not easy to try that we can look at other stuff first.
Can you run this command and then upload the /var/log/letsencrypt/letsencrypt.log
file
sudo certbot renew --dry-run --cert-name help.hellobonafide.com
linkp
July 7, 2023, 3:57am
18
Exempt the .well-known/acme-challenge
path from redirection and you should achieve your desired results.
The --nginx authenticator does that automatically. It makes temp changes that look something like below and removes them after the request
server {rewrite ^(/.well-known/acme-challenge/.*) $1 break; # managed by Certbot
listen 80;
listen [::]:80;
server_name example.com www.example.com;
root /var/www/html;
location = /.well-known/acme-challenge/MxkxRxkxzxkxgxHxvxkxOxpxkxVxkx8xkx4xFxExuxg {default_type text/plain;return 200 MxkxRxkxzxkxgxHxvxkxOxpxkxVxkx8xkx4xFxExuxg.AwQwgwgwzwgwJwgw4wew3wrwxwiw-wpwvwqwxwBwswT;} # managed by Certbot
linkp
July 7, 2023, 4:06am
20
I did not notice mention of the certbot nginx plugin being used. Are you certain that is being used here?
