Ssl: certificate_verify_failed
My domain is: aaasv-cistest-d002.internal.app3as-cloud.local
I ran this command: certbot certonly --standalone -d aaasv-cistest-d002.internal.app3as-cloud.local
An unexpected error occurred:
requests.exceptions.SSLError: HTTPSConnectionPool(host='pki.3as-cloud.com', port=443): Max retries exceeded with url: /acme/ (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate in certificate chain (_ssl.c:1131)')))
The operating system my web server runs on is (include version): Ubuntu 20.04.6
My hosting provider, if applicable, is: no idea
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.10.0
You aren't ever going to get a Let's Encrypt certificate for anything under the local TLD. Let's Encrypt only issues certificates for valid public hostnames and local is not a public TLD. It is reserved for use with mDNS.
Any FQDN in the certificate request must resolve in public DNS.
Looks like they're running their own ACME server at pki.3as-cloud.com (which is not an existing hostname on the public DNS, probably internally too?)
I'm guessing their internal ACME server at pki.3as-cloud.com also uses a certificate from their own CA, but that private CAs root certificate isn't trusted by the host running Certbot.
But that's only guessing due to a lack of information.
