Try your browser to:
http://MYEXTERNAL.IP/
and
https://MYEXTERNAL.IP/
and
http://MYEXTERNAL.IP:443/
Which look similar?
Which return anything?
and
and
Which look similar?
Nothing return all of them
Problem loading page
Well…
I think we hit a wall.
My best guess is that your HTTPS section is missing the “turn SSL on” command and is serving HTTP via port 443.
But we can’t confirm nor deny anything at this point / from this vantage point.
Try connecting the second system back to the same LAN as the Vaio.
And hit MYINTERNAL.IP instead.
Give some minute sir , sorry I will be back soon
So system is back to the same network as vaio and both http & https 192.168.1.26/nextcloud are served
openssl shows more output?
[more like google?]
yes correct
its same like google output
Then maybe your router is messing with things…
yes, I am imaging something like this
Really appreciate for your help, regardless if we have results or not.
Thank you very much
Best of luck to you and cheers from Miami
