SSL certificate generation failure with IIS 8.5 and PleskWin
Detail: Error creating new order :: too many failed authorizations recently: see Failed Validation Limit - Let's Encrypt
Is there a question you have about the rate limit described on that web page?
If you want help with the failures please complete the form you were shown as best you can.
I just realized you posted twice about this same problem. Please do not do that.
But, from that other thread we know your:
My domain is: coris-bourse.com/
serveur: 178.170.62.51: error message when generating the certificate
I don't have a question, I provided the address of the service and the domain name. I have an error message in the generation of the ssl
Yes, as described by that page you have tried to request a cert but have failed too many times. If you want help debugging those failures please complete more answers
My web server is (include version):178.170.62.51:
I have provided the information requested below
I see from your server's responses that your server is IIS 8.5 and you are using PleskWin
I do not have experience with that kind of system. I changed the title so other volunteers with that experience will notice it.
And what's the purpose of your thread if you don't have a specific question?
Where?
Hi, try Certify The Web https://certifytheweb.com or win-acme https://www.win-acme.com/ as the tool to renew your certificates for IIS. You may want to use a different CA if you are still hitting Let's Encrypts rate limit for failed authorizations.
Currently whatever tool you are using is allowing validation requests to reach IIS which in turn is returning your 404 not found page. For this to work without one of the above special tools the webserver needs to be configured to serve the http challenge response files. Normally this is handled by a plugin for wordpress or plesk and presumably that's what you used before, but it's clearly not working now.
Note that everyone here is a volunteer and nobody is obligated to help you, so please provide as much information as you can to allow them to help if they can. Currently you are being reluctant to provide more information, which does not help the people who are trying to help you.
