SSL Certbot errors
Oh yeah it worked.
And this is the vhconf.conf
docRoot $VH_ROOT/html/
enableGzip 1
errorlog $VH_ROOT/logs/error.log {
useServer 1
logLevel DEBUG
rollingSize 10M
accesslog $VH_ROOT/logs/access.log {
useServer 0
rollingSize 10M
keepDays 30
compressArchive 0
index {
useServer 0
indexFiles index.html, index.php
autoIndex 0
autoIndexURI /_autoindex/default.php
errorpage 404 {
url /error404.html
expires {
enableExpires 1
accessControl {
allow *
realm SampleProtectedArea {
userDB {
location conf/vhosts/Example/htpasswd
maxCacheSize 200
cacheTimeout 60
groupDB {
location conf/vhosts/Example/htgroup
maxCacheSize 200
cacheTimeout 60
context /.well-known/ {
location /usr/local/lsws/Example/html/
allowBrowse 1
addDefaultCharset off
context / {
type appserver
location /usr/local/lsws/Example/html/demo/
binPath /usr/local/lsws/fcgi-bin/lswsgi
appType wsgi
startupFile demo/wsgi.py
env PYTHONHOME=/usr/local/lsws/Example/html/
rewrite {
enable 1
autoLoadHtaccess 1
logLevel 0
vhssl {
keyFile /usr/local/lsws/conf/example.key
certFile /usr/local/lsws/conf/example.crt
certChain 1
Ah, I think I (finally) see what is happening.
The URL is being doubled up due to the way the configuration is written:
$ curl -X GET -i jeffwebsite.dev/.well-known/.well-known/acme-challenge/acme-test-2
HTTP/1.1 200 OK
Could you take this:
and change:
to:
location /usr/local/lsws/Example/html/.well-known/
Then do a graceful restart of Litespeed.
Then try again:
sudo certbot certonly --webroot -w /usr/local/lsws/Example/html/ -d jeffwebsite.dev -d www.jeffwebsite.dev --dry-run
omg it worked!
root@mywebsite:/usr/local/lsws/Example/html/demo# sudo certbot certonly --webroot -w /usr/local/lsws/Example/html/ -d jeffwebsite.dev -d www.jeffwebsite.dev
http-01 challenge for jeffwebsite.dev
http-01 challenge for www.jeffwebsite.dev
Using the webroot path /usr/local/lsws/Example/html for all unmatched domains.
Waiting for verification…
    /etc/letsencrypt/live/jeffwebsite.dev/fullchain.pem
    /etc/letsencrypt/live/jeffwebsite.dev/privkey.pem
    Your cert will expire on 2020-11-23. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot
    again. To non-interactively renew all of your certificates, run
    “certbot renew”
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
Thank you so much!
