SSL Cert established on my machine but not on others
csyyc.ca
I installed certbot for my distro
ssl cert which works for my machine but not all others
Apache/2.4.58
Ubunto 20.04 LTS
linode
no
certbot 4.0.0
So yeah, for my machine it's secure for some others it isn't.
Welcome @cFire
Is it possible those other people are using your www subdomain?
Because you got a cert for your apex domain but it doesn't include the www subdomain. Anyone using that will be able to connect but will be shown a message about invalid domain name (in that it is not in the cert name list).
Your previous GoDaddy cert had both names. You didn't specify the command you used but for Certbot you just use two -d options one for each domain name.
Would using the subdomain www make the browser react saying it is “unsafe?” maybe with https:// appended? Could it also be an expired ssl cert? which makes no sense
Yes, very likely. Different browsers may show different wording. It could show HTTPS in the address bar as it could make an HTTPS connection.
Some browsers might show HTTP in the address bar. Depends on which browser, version, and its configuration.
The key issue is if you want people to use the www subdomain your cert must include that name.
