Speedtest SSL certificate problem: self signed certificate
  • https
    • details : Response: , Error: SSL certificate problem: self signed certificate
    • tip : Connection over HTTPS failed.
    • status : FAILED.
I can't, cuz I don't have permission for this. Sorry.
openssl s_client -connect mydomain.xxx.xx
140638376744064:error:0200206F:system library:connect:Connection refused:../crypto/bio/b_sock2.c:110:
140638376744064:error:2008A067:BIO routines:BIO_connect:connect error:../crypto/bio/b_sock2.c:111:
140638376744064:error:02002065:system library:connect:Network is unreachable:../crypto/bio/b_sock2.c:110:
apache2
debian 10.10
Hi @cCosta and welcome to the LE community forum :slight_smile:
Without a domain name, it is very difficult for anyone here to provide useful help.
The best we can do is provide generic information.
Like:
That should end with :443
As in:
echo | openssl s_client -connect acme-v02.api.letsencrypt.org:443 | head
This output is a bit confusing:
That you have Apache2 is not surprising.
[too many of the messes seen here seem to be with Apache misconfigurations]
Overall: I don't see how this is related to this site at all.
  • No indication that an LE cert is being used.
  • No indication that certbot is being used.
    [form question left empty]
  • No indication that any ACME client is being used.
Thanks for any help.
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = acme-v01.api.letsencrypt.org
verify return:1
DONE
CONNECTED(00000003)
Certificate chain
 0 s:CN = acme-v01.api.letsencrypt.org
That looks good.
Now try the same thing but using your FQDN.
echo | openssl s_client -connect mydomain.xxx.xx:443 | head
140280264868992:error:0200206F:system library:connect:Connection refused:../crypto/bio/b_sock2.c:110:
140280264868992:error:2008A067:BIO routines:BIO_connect:connect error:../crypto/bio/b_sock2.c:111:
140280264868992:error:02002065:system library:connect:Network is unreachable:../crypto/bio/b_sock2.c:110:
connect:errno=101
If I destroy and recreate the same VM with the same config, IP address and dns, I can certify the server again. Why?
