[Solved] Webroot Renewal Fails
Thanks!
How are you creating your test files in /var/www/html/mail.nietostack.com/.well-known/acme-challenge (the ones that we can see in our browsers)?
Through my FTP client
And your Apache error log after the recent failure?
error.txt (8.2 KB)
Attached. Thanks Osiris
There’s no log of a http-01 request, but I did see this:
[Tue Oct 31 06:43:35.287342 2017] [:error] [pid 29661] [client 189.56.90.242:11128] script '/var/www/html/mail.nietostack.com/public_html/index.php' not found or unable to stat
Are you sure the DocumentRoot isn’t set to /var/www/html/mail.nietostack.com/public_html/?
If so, your webroot path should match accordingly.
Looking at the Apache config, that seems to be the case. Can I modify the LetsEncrypt config for this site to point to /public_html/?
The file /etc/letsencrypt/renewal/mail.nietostack.com.conf should contain a variable called webroot_path which should correspond with the DocumentRoot variable of Apache.
Osiris, thank you! That was it. I looked at that before starting this thread but just was not connecting the pieces…
Schoen and rg305, thank you for all your assistance as well!
**          (The test certificates below have not been saved.)
  /etc/letsencrypt/live/www.mitchelnieto.com/fullchain.pem (success)
  /etc/letsencrypt/live/nietostack.com/fullchain.pem (success)
  /etc/letsencrypt/live/www.mitchelnieto.tech/fullchain.pem (success)
  /etc/letsencrypt/live/mail.nietostack.com/fullchain.pem (success)
  /etc/letsencrypt/live/nietofamily.com/fullchain.pem (success)
**          (The test certificates above have not been saved.)
