os: ubuntu 16.04
server: nginx
authorization: standalone
background: the server is configured to handle 20+ “known” domains (hardcoded into nginx) and an infinite number of unknown (whitelabel serviced domains) using 2 acme clients for letsencrypt (different storage/deployment policies).
the problem i’m having is with the selection of domains handled by certbot. we previously did tls(non-http) auth for a handful of domains. this was to simplify the logical partitioning within nginx config files of what gets handled where.
we’ve reconfigured nginx to route the right domains into the right place, and the way we want. the intention is to bind certbot’s standalone webserver to port 81 for http-01, and proxy the port 80 request to the local 81. automated tests confirm nginx works as expected.
my problem is that the expected command isn’t working as intended:
./certbot-auto renew --standalone --http-01-port=81 --force-renewal
this strategy has worked in the past. [I’m doing the --force-renewal to make sure the client runs against acme and successfully renews on port80, as I have time to do this now but won’t next month.]
this is resulting in a problem binding to port 443:
Processing /etc/letsencrypt/renewal/internetfunzone.com.conf
tls-sni-01 challenge for internetfunzone.com
Attempting to renew cert (internetfunzone.com) from /etc/letsencrypt/renewal/internetfunzone.com.conf produced an unexpected error: Problem binding to port 443: Could not bind to IPv4 or IPv6.. Skipping.
this is where I get lost. tsl wasn’t mentioned in the renewalparams. i know, because I had just removed all the pre/post hooks in everything (we no longer start/stop nginx as part of renewal. it’s handled elsewhere during the day). just to be safe and not seem crazy, I double checked
version = 0.19.0
cert = /etc/letsencrypt/live/internetfunzone.com/cert.pem
privkey = /etc/letsencrypt/live/internetfunzone.com/privkey.pem
chain = /etc/letsencrypt/live/internetfunzone.com/chain.pem
fullchain = /etc/letsencrypt/live/internetfunzone.com/fullchain.pem
archive_dir = /etc/letsencrypt/archive/internetfunzone.com
[renewalparams]
authenticator = standalone
installer = None
account = --------------
I can’t figure out why it’s still trying to run tls challenges against 443. i’m using certbot-auto too, so it should be auto updating.
i haven’t touched the certbot client in a while, so I’m just lost. does anyone know what config options I’m missing or screwed up?
