SOLVED Possible? Nginx and Apache on same machine both using SSL
My domain is: backend.atavismxi.com and cloud.atavismxi.com
I ran this command: sudo certbot --apache -d cloud.atavismxi.com
Deploying certificate
Successfully deployed certificate for cloud.atavismxi.com to /etc/httpd/conf/extra/nextcloud-le-ssl.conf
Congratulations! You have successfully enabled HTTPS on https://cloud.atavismxi.com
My web server is (include version): Apache and Nginx
The operating system my web server runs on is (include version): Arch Linux
My hosting provider, if applicable, is: Netlify
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.21
Hello~ I might be asking this at wrong place. If I am please forgive me and I'll move onto some place like apache forums or next cloud forums.
My problem is that I have a server setup with nginx and apache. Used certbots with both to obtain certficates and both seem to work fine. Problem is that I can't run nginx and apache at the same time. Apache says things like this when I start it:
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:443
So I believe that means nginx is already using port 443 and apache can't use it? I have nginx configured to use port 80 and apache using port 8080. Is there a way to use both apache and nginx on port 443?
Not on the same IP.
What is it you are trying to accomplish?
Show:
netstat -pant | grep -i listen | grep 443
What I'm trying to accomplish: I'm trying to keep my website running and setup nextcloud
Ahhh... OK
But why have both Apache and nginx ?
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 73091/nginx: master
Well I tried to get Nextcloud working with nginx.......couldn't do it. Wouldn't even load without SSL and just using port 8080. I can go back to trying that if I need to. I probably just had something wrong in my nginx server block. Apache works fine without SSL using port 8080.
If you "copy" the vhost details of the working apache on 8080, you should be able to use them in nginx with 443.
OK. That took a while. But good advice. I copied the template for nginx from next cloud: NGINX configuration — Nextcloud latest Administration Manual latest documentation
Changed server name to cloud.testing.com
changed root to /usr/share/webapps/nextcloud/
changed the ssl lines to my ssl certficate
Still didn't work. Then i saw on the arch linux wiki it says to use
server unix:/run/nextcloud/nextcloud.sock;
instead of server 127.0.0.1:9000; that the nextcloud documents says to use
Then it worked with nginx and I have SSL with both servers.
You're amazing
