SOLVED ! Nginx keeps looping - Docker - Certificate not found
Hello all !
Since a couple of days I have the following error while trying to generate a new certificate for my subdomain that saying the certificates are not found and so the container keeps restarting in loop.
I would like to mention that the only thing that change on the server is the fact that I added some iptables rules because my server got massively DDoS attacked/bruteforced. But nothing else has change in the server side, I didn't change any permissions for folders etc.. or something else.
I would also like to mention that all my subdomains have the same configuration and the other subdomains are working perfectly.
This one used to work perfectly also.
*Server version : *
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
When I run the initletsencrypt.sh :
Certificate is saved at: /etc/letsencrypt/live/husky/fullchain.pem
Key is saved at: /etc/letsencrypt/live/husky/privkey.pem
This certificate expires on 2023-07-19.
NEXT STEPS:
- The certificate will need to be renewed before it expires. Certbot can automatically renew the certificate in the background, but you may need to take steps to enable that functionality. See User Guide — Certbot 2.5.0 documentation for instructions.
### Reloading nginx ...
Error response from daemon: Container CONTAINER_ID is restarting, wait until the container is running
When I check the logs from the nginx container (docker ps CONTAINER_ID), I have the following error :
I'm more interest about the certificate issue than the server issue :
2023/04/20 19:21:50 [emerg] 1#1: host not found in upstream "server:8000" in /etc/nginx/conf.d/app.conf:70
nginx: [emerg] host not found in upstream "server:8000" in /etc/nginx/conf.d/app.conf:70
2023/04/20 19:21:51 [emerg] 1#1: cannot load certificate "/opt/husky/bsc/release-data/certbot/conf/live/husky/fullchain.pem": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/opt/husky/bsc/release-data/certbot/conf/live/husky/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
nginx: [emerg] cannot load certificate "/opt/husky/bsc/release-data/certbot/conf/live/husky/fullchain.pem": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/opt/husky/bsc/release-data/certbot/conf/live/husky/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
2023/04/20 19:21:52 [emerg] 1#1: cannot load certificate "/opt/husky/bsc/release-data/certbot/conf/live/husky/fullchain.pem": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/opt/husky/bsc/release-data/certbot/conf/live/husky/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
When I check the folder I have the files :
root@synan:/opt/husky/bsc/release-data/certbot/conf/live/husky# ls -l
total 4
-rw-r--r-- 1 root root 692 Apr 20 12:21 README
lrwxrwxrwx 1 root root 31 Apr 20 12:21 cert.pem -> ../../archive/husky/cert1.pem
lrwxrwxrwx 1 root root 32 Apr 20 12:21 chain.pem -> ../../archive/husky/chain1.pem
lrwxrwxrwx 1 root root 36 Apr 20 12:21 fullchain.pem -> ../../archive/husky/fullchain1.pem
lrwxrwxrwx 1 root root 34 Apr 20 12:21 privkey.pem -> ../../archive/husky/privkey1.pem
Also the interesting part of my docker-compose.yml file for this subdomain :
nginx:
image: nginx:1.21-alpine
restart: unless-stopped
volumes:
- ./release-data/nginx:/etc/nginx/conf.d
- ./release-data/certbot/conf:/etc/letsencrypt
- ./release-data/certbot/www:/var/www/certbot
ports:
- "8085:80"
- "4385:443"
command: "/bin/sh -c 'while :; do sleep 6h & wait $${!}; nginx -s reload; done & nginx -g "daemon off;"'"
certbot:
image: certbot/certbot
volumes:
entrypoint: "/bin/sh -c 'trap exit TERM; while :; do certbot renew; sleep 12h & wait $${!}; done;'"
volumes:
redis:
Do you have an idea ?
Thank you !
Hello @synan, welcome to the Let's Encrypt community. :slightly_smiling_face:
Thank you for assisting us in helping YOU!
What shows?:
ls -l /opt/husky/bsc/release-data/certbot/conf/live/husky/
ls -l /opt/husky/bsc/release-data/certbot/conf/archive/husky/
ls -l /etc/letsencrypt/live/husky/
ls -l /etc/letsencrypt/archive/husky/
find / -name cert1.pem
root@synan:~# ls -l /opt/husky/bsc/release-data/certbot/conf/live/husky/
total 4
root@synan:~# ls -l /opt/husky/bsc/release-data/certbot/conf/archive/husky/
total 20
-rw-r--r-- 1 root root 2220 Apr 20 12:21 cert1.pem
-rw-r--r-- 1 root root 3749 Apr 20 12:21 chain1.pem
-rw-r--r-- 1 root root 5969 Apr 20 12:21 fullchain1.pem
-rw------- 1 root root 3272 Apr 20 12:21 privkey1.pem
root@synan:~# ls -l /etc/letsencrypt/live/husky
ls: cannot access '/etc/letsencrypt/live/husky': No such file or directory
It seems that the letsencrypt folder doesn't exist.
But my configuration is working perfectly for the other subdomains and also worked for this one in the past.
root@synan:/etc# find / -name cert1.pem
/var/lib/docker/overlay2/ce4715404141e31fed7b7992a4194957890be58fcf41be6d6a6e0c70288b5942/diff/opt/certbot/src/certbot/certbot/tests/testdata/sample-archive-ec/cert1.pem
/var/lib/docker/overlay2/ce4715404141e31fed7b7992a4194957890be58fcf41be6d6a6e0c70288b5942/diff/opt/certbot/src/certbot/certbot/tests/testdata/sample-archive/cert1.pem
/var/lib/docker/overlay2/d5fa565b503b97a2d40d620b0cd56108205fb16326661ab6c5d6142f3f830c66/merged/opt/certbot/src/certbot/certbot/tests/testdata/sample-archive-ec/cert1.pem
/var/lib/docker/overlay2/d5fa565b503b97a2d40d620b0cd56108205fb16326661ab6c5d6142f3f830c66/merged/opt/certbot/src/certbot/certbot/tests/testdata/sample-archive/cert1.pem
/opt/husky/bsc1/release-data/certbot/conf/archive/husky/cert1.pem
/opt/husky/bsc2/release-data/certbot/conf/archive/husky/cert1.pem
/opt/husky/bsc3/release-data/certbot/conf/archive/husky/cert1.pem
/opt/husky/bsc4/release-data/certbot/conf/archive/husky/cert1.pem
/opt/husky/bsc/release-data/certbot/conf/archive/husky/cert1.pem
/opt/husky/bsc5/release-data/certbot/conf/archive/husky/cert1.pem
That fails to find a file while looking in path:
But searching shows those files exist in the links for that path:
So...
I'm thinking that permissions are to blame.
Which permissions ? On which files/folders ?
This one is specifically mentioned in the fopen() failure:
Okay I need to wait as I reached the limit to generate a new request and will update the post then !
Thanks mate :slight_smile:
Testing and debugging are best done using the Staging Environment as the Rate Limits are much higher. Rate Limits are per week (rolling).
And to assist with debugging there is a great place to start is Let's Debug.
The file got the same right as the others :
total 4
-rw-r--r-- 1 root root 692 Apr 21 11:15 README
lrwxrwxrwx 1 root root 31 Apr 21 11:15 cert.pem -> ../../archive/husky/cert1.pem
lrwxrwxrwx 1 root root 32 Apr 21 11:15 chain.pem -> ../../archive/husky/chain1.pem
lrwxrwxrwx 1 root root 36 Apr 21 11:15 fullchain.pem -> ../../archive/husky/fullchain1.pem
lrwxrwxrwx 1 root root 34 Apr 21 11:15 privkey.pem -> ../../archive/husky/privkey1.pem
hmm...
I guess that's as far as I can "help".
I'm not familiar with this configuration :frowning:
I solved the issue !
Thank you :slight_smile:
The post you marked as “Solution” does not have any solution in it, please explain what you did or tag the right post. :slightly_smiling_face:
