Deployed Certificate to VirtualHost /etc/nginx/conf.d/default.conf for dev.xxxx.com
nginx: [emerg] duplicate listen options for [::]:443 in /etc/nginx/conf.d/default.conf:95
Rolling back to previous server configuration…
My web server is (include version): nginx version: nginx/1.13.1
The operating system my web server runs on is (include version): ubuntu 14
I can login to a root shell on my machine : yes
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): putty
I'm happy to hear you solved your problem! Can you share what you fixed? That way I can mark the thread solved and you may help someone else down the road who has a similar problem.
