I was reading the guide here: https://community.letsencrypt.org/t/quick-start-guide/1631
and was unable to follow the steps listed. Below is the output from terminal. Is there an error log found somewhere that I can post?
OS: Debian 7.9 wheezy
Server version: Apache/2.2.22
Requesting root privileges to run with virtualenv: /root/.local/share/letsencrypt/bin/letsencrypt
No installers seem to be present and working on your system; fix that or try running letsencrypt with the "certonly" command
root@root:~/letsencrypt# ./letsencrypt-auto --apache
Updating letsencrypt and virtual environment dependencies......
Requesting root privileges to run with virtualenv: /root/.local/share/letsencrypt/bin/letsencrypt --apache
The apache plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('Unable to parse runtime variables',)
