I’m running a server on digitalocean. My domain is used the default A record setting (Name: “@”, IP: IP from my server).
If I run
sudo docker run -it --rm -p 443:443 --name letsencrypt \
-v "/etc/letsencrypt:/etc/letsencrypt" \
-v "/var/lib/letsencrypt:/var/lib/letsencrypt" \
quay.io/letsencrypt/letsencrypt:latest auth
on my server and enter my data, I get the following error:
Failed authorization procedure. www.example.com (dvsni): connection :: The server could
not connect to the client for DV :: Failed to connect to host for DVSNI challenge, example.com
(simpleHttp): unauthorized :: The client lacks sufficient authorization :: Invalid response from
http://example.com/.well-known/acme-challenge/qKshnYm1uFGtAvrnNvVdWFRXGg5mYzJbIFRNtphUsAs
[some IP]: 500
- The following 'connection' errors were reported by the server:
Domains: example.com
Error: The server could not connect to the client for DV
entered correctly and the DNS A record(s) for that domain contains
the right IP address. Additionally, please check that your computer
has publicly routable IP address and no firewalls are preventing
the server from communicating with the client.
- The following 'unauthorized' errors were reported by the server:
Domains: www.example.com
Error: The client lacks sufficient authorization
Any ideas whats wrong?
