SOLVED: Command not found
https://little-beak.com
certbot, and sudo cerbot
command not found
Apache/2.4.25 (Debian)
Debian 9 (I know, I will update soon)
N/A
N/A
-bash: certbot: command not found
-bash: certbot-auto: command not found
A little background, I have used certbot for years on my Debian server, without issue, always without problems kudos. The bad thing is, I am not really practiced in solving problems with Certbot. But, My certificate is not updating.
More critical, I can't find the certbot command =( I have used certbot (not certbot-auto, or letscrypt-auto, or anything, but certbot). It has always worked with altering, changing, or updating certificates, if I did any manually. All the automated ones worked perfectly as well.
I tried a locate, and found a "certbot" in my /usr/bin directory. But, in fact, it was not really there, I had to update my locate database. Once I did that, I had less references to certbot.
Then, I ran sudo find / -type f -name certbot 2>/dev/null, per reading another post on the topic on the forums, and got the following ouput:
/etc/logrotate.d/certbot
/etc/cron.d/certbot
But, my guess is that those are not the application for updating, etc??
I am guessing that over time, I must have updated, and things changed??
I am really at my wits end, and my email server, cloud, etc. are now funky. I have another certificate, with *.org in the end. Maybe I configured the last certificate wrong, as I want *.com to be the main certificate. But, the current situation is I cannot find certbot to fix things. =(
Thanks in advance, and thanks for reading if you made it this far.
EDIT: looking more closely, I think I falsely configured little-beak.org as the head of the certificate instead of .com..But, unfortunately I need it back to .com.
Well, it seems something or someone has removed certbot from your system. You probably can re-install certbot following the applicable guide on https://certbot.eff.org/ again.
Also, maybe you can run history | grep certbot to find out if there is an entry which removed certbot? Probably required to run as root, I dunno if sudo works for history as I think it's a Bash buildin function.
Whoa you scared me =) But, the history via root or sudo user show it being removed, at all. It just showed my recent searches for it, and my last command.
It looks good, the cert name should be "little-beak.com" which has apparently expired.
I guess I will just re-install certbot, and see how that goes.
Just re-installing it seemed to work. I guess I use snap now.
