I ran this command: ./certbot-auto certonly -n --agree-tos --email admin@bsidesslc.org --domain bsidesslc.org --webroot --webroot-path /var/www/vhosts/bsidesslc.org/httpsdocs/
It produced this output: Failed authorization procedure. bsidesslc.org (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to www.bsidesslc.org.well-known
Domain: bsidesslc.org
Type: connection
Detail: Could not connect to www.bsidesslc.org.well-known
You have http://bsidesslc.org/ configured to redirect to http://www.bsidesslc.org – notice that one ends in a slash, and one doesn’t.
http://bsidesslc.org/.well-known/acme-challenge/foo is genuinely redirecting to http://www.bsidesslc.org.well-known/acme-challenge/foo. You can see for yourself with your browser or a tool like curl.
I’m not an Apache expert, but you need to check your RewriteRule or whatever sends the redirect, and add a / somewhere.
You can also configure http://bsidesslc.org/.well-known/acme-challenge/ not to redirect at all, if you prefer, but it’s not necessary. I don’t know how to do so in Apache – if it’s possible at all – off the top of my head.
(A non-buggy redirect isn’t a problem, as long as http://www.bsidesslc.org/.well-known/acme-challenge/ is configured to serve the challenge files from the proper directory.)
