That's your internal ip address. So your configuration is buggy - so fix it.
Which configuration ? Do you know how to fix it ?
I have no idea about your configuration.
164.132.207.108 returns a "Bad gateway", so this ip works, but the destination doesn't work.
If you use internal proxy servers, you should know your configuration.
Okay, i just solved the Bad Gateway error, in fact it was an error in php.
The more, i just noticed that if i use another port on my browser, there isnāt any redirection so itās only on 80
Well, if nginx server replies by 'bad gateway', the nginx configuration is faulty.
Configuration can be formally correct but forward to a destination that is not responsive, an invalid proxy_pass for example.
OMG, iām just so dumb, everything is working now, i just totally forgotten to clear my cacheā¦
