Running command:
sudo ./certbot-auto --debug -v --server https://acme-v02.api.letsencrypt.org/directory certonly -d mydomain.com
The certbot was updated and is currently running version 1.3.0
All my commands using the acme-v02, and with the updated certbot, why else should this fail, when running, it automatically upgraded and that’s when this error came through. I’ve been running just fine for a couple of years now.
Using on EC2 Amazon Linux with Apache.
Exiting abnormally:
File "/opt/eff.org/certbot/venv/bin/letsencrypt", line 11, in <module>
sys.exit(main())
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py", line 15, in main
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/_internal/main.py", line 1347, in main
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/_internal/main.py", line 1217, in certonly
le_client = _init_le_client(config, auth, installer)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/_internal/main.py", line 603, in _init_le_client
acc, acme = _determine_account(config)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/_internal/main.py", line 519, in _determine_account
config, account_storage, tos_cb=_tos_cb)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/_internal/client.py", line 176, in register
regr = perform_registration(acme, config, tos_cb)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/_internal/client.py", line 219, in perform_registration
return acme.new_account_and_tos(newreg, tos_cb)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/client.py", line 829, in new_account_and_tos
regr = self.client.register(regr)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/client.py", line 277, in register
response = self._post(self.directory[new_reg], new_reg)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/client.py", line 95, in _post
return self.net.post(*args, **kwargs)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/client.py", line 1174, in post
return self._post_once(*args, **kwargs)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/client.py", line 1187, in _post_once
response = self._check_response(response, content_type=content_type)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/client.py", line 1045, in _check_response
raise messages.Error.from_json(jobj)
Error: urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Account creation on ACMEv1 is disabled. Please upgrade your ACME client to a version that supports ACMEv2 / RFC 8555. See https://community.letsencrypt.org/t/end-of-life-plan-for-acmev1/88430 for details.
