Site not secured, despite successful certbot command
My site is not secured after running the below command. I then get these warnings alongside it:
nginx: [warn] conflicting server name “chairbirds.com” on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name “chairbirds.com” on 0.0.0.0:443, ignored
I have looked through my nginx configurations files so many times, and I don’t know what is wrong. I’ve been reading that I may have duplicate records or something, but I couldn’t find anything duplicated. The command nginx -T shows me my configurations, but at the very top I see the warnings above.
Here is the output from the nginx -T command: https://pastebin.com/ZCE80mtE
My domain is: chairbirds.com
I ran this command: sudo certbot --nginx
1: chairbirds.com
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/chairbirds.com.conf)
What would you like to do?
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/default
nginx: [warn] conflicting server name "chairbirds.com" on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name "chairbirds.com" on 0.0.0.0:443, ignored
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Traffic on port 80 already redirecting to ssl in /etc/nginx/sites-enabled/default
Congratulations! You have successfully enabled https://chairbirds.com
https://www.ssllabs.com/ssltest/analyze.html?d=chairbirds.com
   /etc/letsencrypt/live/chairbirds.com/fullchain.pem
   /etc/letsencrypt/live/chairbirds.com/privkey.pem
   Your cert will expire on 2020-12-03. To obtain a new or tweaked
   with the "certonly" option. To non-interactively renew *all* of
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
My hosting provider, if applicable, is: Digital Ocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Please check for server_name (or the lack of it) in your server blocks below listen 80 and listen 443.
Hi @Chair
use the search, then you will find the duplicated definition.
That's
    listen 80;
    listen 443 ssl;
    server_name chairbirds.com;
always bad, never mix http and https in one definition.
And
server_name chairbirds.com; # managed by Certbot
certbot seems to think there's already a redirect in place. But your site doesn't have a redirect currently.. Which is strange. What's the contents of /etc/nginx/sites-enabled/default?
Sorry, I am not that knowledgeable on http and https. I tried commenting out listen 80 and listen 443 separately, but none of that resolved the issue. Should I remove one of the server_name options?
Yes you should remove the extra server_name.
The contents of my /etc/nginx/sites-enabled/default are:
        listen 80 default_server;
        # SSL configuration
        root /var/www/html;
        server_name _;
                try_files $uri $uri/ =404;
        #location ~ \.php$ {
        #       include snippets/fastcgi-php.conf;
        #       # With php-fpm (or other unix sockets):
        #       fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
        #       # With php-cgi (or other tcp sockets):
        root /var/www/html;
    ssl_certificate /etc/letsencrypt/live/chairbirds.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/chairbirds.com/privkey.pem; # managed by Certbot
    if ($host = chairbirds.com) {
    } # managed by Certbot
        listen 80 ;
        listen [::]:80 ;
From which file? I have it on /etc/nginx/sites-enabled/default and /etc/nginx/sites-enabled/cybirds.conf.
For some reason, there’s an extra HTTP (port 80) server {} block. I would suggest to comment out the first server { .. } section. It’s just the default nginx server block which isn’t really needed, as you’ve got a brand new HTTPS server section now and a (second?) HTTP server block at the end of the file which will redirect HTTP to HTTPS.
I’ve commented it out, and I reloaded nginx. My site still doesn’t seem to be secured. Should I try running certbot again?
What’s the files contents now? Or even better: what’s the output of nginx -T? Because I’m thinking there are more files at play here.
After commenting out the first server { .. }, I now have:
        root /var/www/html;
        #       fastcgi_pass 127.0.0.1:9000;
        # concurs with nginx's one
        #location ~ /\.ht {
        #       deny all;
        listen 80 ;
        listen [::]:80 ;
The output of the nginx -T command is here:
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
	worker_connections 768;
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	keepalive_timeout 65;
	types_hash_max_size 2048;
	# server_tokens off;
	# SSL Settings
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
	ssl_prefer_server_ciphers on;
	# Logging Settings
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
	# gzip_comp_level 6;
	# gzip_buffers 16 8k;
	# gzip_http_version 1.1;
	# Virtual Host Configs
#mail {
#	# See sample authentication script at:
#	# http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#	# auth_http localhost/auth.php;
#	# pop3_capabilities "TOP" "USER";
#	# imap_capabilities "IMAP4rev1" "UIDPLUS";
#	server {
#		listen     localhost:110;
#		protocol   pop3;
#		proxy      on;
#	server {
#		listen     localhost:143;
#		protocol   imap;
#		proxy      on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/sites-enabled/cybirds.conf:
upstream cybirds {
    server unix:/home/chris/mezzanine/cybirds/gunicorn.sock fail_timeout=0;
    listen 80;
    listen 443 ssl;
    client_max_body_size 10M;
    keepalive_timeout    15;
    error_log /home/chris/logs/cybirds_error_nginx.log info;
     ssl_certificate      conf/cybirds.crt;
     ssl_certificate_key  conf/cybirds.key;
     ssl_session_cache    shared:SSL:10m;
     ssl_session_timeout  10m;
     ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA;
     ssl_protocols TLSv1.2 TLSv1.1 TLSv1;
    # Deny illegal Host headers
    if ($host !~* ^(chairbirds.com)$) {
        return 444;
        proxy_redirect      off;
        proxy_set_header    Host                    $host;
        proxy_set_header    X-Real-IP               $remote_addr;
        proxy_set_header    X-Forwarded-For         $proxy_add_x_forwarded_for;
        proxy_set_header    X-Forwarded-Protocol    $scheme;
        proxy_pass          http://cybirds;
    location /static/ {
        root            /home/chris/mezzanine/cybirds;
        access_log      off;
        log_not_found   off;
        expires 30d;
    location /robots.txt {
        root            /home/chris/mezzanine/cybirds/static;
        access_log      off;
        log_not_found   off;
    location /favicon.ico {
        root            /home/chris/mezzanine/cybirds/static/img;
        access_log      off;
        log_not_found   off;
    location /media/ {
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
#server {
#	listen 80 default_server;
#	listen [::]:80 default_server;
	# SSL configuration
#	root /var/www/html;
#	index index.html index.htm index.nginx-debian.html;
#	server_name _;
#	location / {
#		try_files $uri $uri/ =404;
	#location ~ /\.ht {
	#	deny all;
#server {
#	listen 80;
#	listen [::]:80;
#	server_name example.com;
#	root /var/www/example.com;
#	index index.html;
#	location / {
	# SSL configuration
	root /var/www/html;
	#location ~ /\.ht {
	#	deny all;
	listen 80 ;
	listen [::]:80 ;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
ssl_ciphers "ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS";
Ok, so your file /etc/nginx/sites-enabled/cybirds.conf also contains a server {} block for chairbirds.com. And it’s way more complicated than the blocks from the default file! For some reason, certbot didn’t detect that one? Strange…
In any case, you should be able to disable the whole default site and modify your cybirds.conf file to point to the correct certificate files:
If you’d like, you could also include the two other directives added by certbot. As far as I know, it uses recommended settings by Mozilla:
Edit: Oh and you can remove the # managed by Certbot comments, as certbot clearly couldn’t manage your nginx configuration for some reason :grin:
How would I disable the default site?
So, I took a look at the link you sent, and it states there should be a file in the sites-available that is used by the domain. I only have a default file in my sites-available directory. So, I imagine the ln -s command may not work? Unless I’m not understand the solution.
I have finally figured out my issue. You helped me solve my problem, and it wasn’t certbots fault at all! Lol, it had every right to comment that it had managed my files. The issue was on my side.
Here is what happened initially:
I ran sudo certbot --nginx before I did any creation or deployment of my project. Therefore, certbot didn’t recognize my new server block once I had deployed after the initial sudo certbot --nginx command. I had just rebuilt my entire Digital Ocean droplet after you had mentioned you found it strange that certbot did not know of my more complicated server block. So, I looked into it further and I have found the solution. I just run sudo certbot --nginx after I have done all my creation and deployment of my project.
I really appreciate the help, Osiris. I hope you have a wonderful day!
