I've been trying to sign a certificate from let's encrypt for a Cisco Router, i'm test with two domain but show me the same result, Down are the info that i hope that be useful
networkconsulting.cloudns.nz
sudo certbot certonly --manual -d networkconsulting.cloudns.nz --agree-tos --manual-public-ip-logging-ok --preferred-challenges dns-01 --server https://acme-v02.api.letsencrypt.org/directory --register-unsafely-without-email --rsa-key-size 2048
Requesting a certificate for networkconsulting.cloudns.nz
Please deploy a DNS TXT record under the name:
_acme-challenge.networkconsulting.cloudns.nz.
with the following value:
jj5PK5hJrI80PxRzBS1torSb9XHHD2iVZ5KE4gViRRc
Before continuing, verify the TXT record has been deployed. Depending on the DNS
provider, this may take some time, from a few seconds to multiple minutes. You can
check if it has finished deploying with aid of online tools, such as the Google
Admin Toolbox: Dig (DNS lookup).
Look for one or more bolded line(s) below the line ';ANSWER'. It should show the
value(s) you've just added.
Press Enter to Continue
Domain: networkconsulting.cloudns.nz
Type: dns
Detail: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.networkconsulting.cloudns.nz - check that a DNS record exists for this domain
Hint: The Certificate Authority failed to verify the manually created DNS TXT records. Ensure that you created these in the correct location, or try waiting longer for DNS propagation on the next attempt.
Router Cisco ISR 4000
UBUNTU 22 /
yes, through
or certbot-auto --version
if you're using Certbot):
$ certbot --version
certbot 1.32.0
Thanks in advanced.
